Flow Numbers and pics of home ported heads!!!
Old Feb 14, 2003 | 11:33 PM
Camaro90RS's Avatar
Talking Flow Numbers and pics of home ported heads!!!
Well today I was able to have the heads flowed that I talk about below. I had them flowed on a SuperFlow SF600 bench, and they were flowed at 28" water, just like everyone else does. The heads flowed alot more air than what I had expected. So you know, a friend of mine did the rough cutting on them, and then I came in and did all the contouring, smoothing and shaping of the ports. This is my first time doing a set of heads, and was a little bit nervous at first. But once he showed me what to do, it went fine. Well here at the before and after flow numbers. I know there is some moron out there that will call BS to these numbers, and if I had a scanner available, I would scan the flow sheet too.
Stock Intake Exhaust
.200 118 84
.300 171 117
.400 201 130
.500 204 138
.600 204 144
Ported Intake Exhaust
.200 129 93
.300 183 130
.400 229 168
.500 262 184
.600 265 192
Here is about the heads.
Well over the last few months, a friend of mine and myself have been working on a set of LT1 heads for my up coming project. The pics of the ports arent that great because the heads were allready together and I couldnt get much light in the bowl area. I used Manley Race Flow 2.00/1.56 valves, valve job, milled the heads down .005, and all the other good stuff. For the valve job, he didnt do the normal 3 sharp degrees for the cuts(30,45,60). The cut has many many little angles, and when you feel it and look at it, you can tell that it is a complete radius with now sharp cuts. HE said that this will help alot with not disturbing the flow. Its hard to tell from the pics but we streamlined the valve guide boss, removed material where necessary, and smoothed and contoured the whole head. I did some smoothing on the short turn radius, and opened up the bowls a fair amount, to where it needed to be. The guy who helped me through the process, happens to build alot of engines, and has his own low 7 sec Dodge Avenger Prostock car. He is a family friend and he offered to help me with the heads. Here is a link to where the pics are
http://groups.msn.com/BriansFbodyPic...03project.msnw
To complement the heads, they will be going along with a ported intake, Comp XE236/242, hooker long tubes, and all the other bolt ons.
Brian
Old Feb 14, 2003 | 11:37 PM
LS1_03's Avatar
Very nice Brian. If anyone calls B.S. on these #'s, I can personally vouch for them, since I live a whole 5 minutes away from him. 3 weeks or so buddy.
Old Feb 15, 2003 | 03:36 AM
VINCELEE123's Avatar
cool
look very nice!!!
vince
Old Feb 15, 2003 | 03:55 AM
bunker's Avatar
Always wanted to know the results, you posted before with just some pics nice now keep me posted on the Dyno numbers/track times hehe.
Old Feb 15, 2003 | 07:13 AM
Camaro90RS's Avatar
up
Old Feb 15, 2003 | 07:41 AM
NightTrain66's Avatar
good #'s.
You should be very happy with the performance.
NightTrain66
Old Feb 15, 2003 | 07:51 AM
drop top steve's Avatar
Very nice, you got a few cfm more than I got from mine, well done.
Old Feb 15, 2003 | 08:35 AM
ArrestMeRed's Avatar
Thats bad *** man! Damn good numbers! I`m gonna have to try it...
Old Feb 15, 2003 | 11:08 AM
LS1_03's Avatar
We'll do that and MAYBE more. I can transfer videos from my camera to my computer, but I gotta get used to using it and stuff. So after the swap is done, and the car is all dialed in you might be seeing some vids of this beast.
Old Feb 15, 2003 | 01:17 PM
chesee48's Avatar
impressive!! wow!
Old Feb 15, 2003 | 02:36 PM
Dr.Mudge's Avatar
If those numbers are legit, your one of only two people that I've seen do VERY well with thier own heads, congrats!
Old Feb 15, 2003 | 03:58 PM
LS1_03's Avatar
How would they not be legit if I may ask? If you say they are not legit because he's not telling the truth then I can assure you he is not lying.
Old Feb 15, 2003 | 05:57 PM
Camaro90RS's Avatar
The numbers are legit, and you really doubt me, call Mike at Hi-Flow heads at 1-708-396-0505. I was just there yesterday, and tell him that Brian Black sent ya. Also, as I mentioned before, I did have some help on the heads, but he showed me where to remove material, and shape etc. If you ask him, he says that I did 85% of the work on the heads.
Brian
Old Feb 15, 2003 | 08:52 PM
LS1_03's Avatar
http://community.webshots.com/photo/...63764082jfWrlS
Click that for the picture of his flowchart for his heads. I'm hosting it for him because he couldn't upload it correctly. If the above link does not work, click the link in my sig and go to the "Brian's T/A" album and you'll see it.
Old Feb 15, 2003 | 10:48 PM
Dr.Mudge's Avatar
Nobody is doubting you that I've seen Brian, congrats on the numbers, your hard work payed off.
