Flo Pro Twister Mufflers?
Old Jan 13, 2004 | 04:15 PM
Gripenfelter's Avatar
Anyone try these yet?
They're like Bullets.
http://www.flopro.com/Twister.htm
Video of True Duals with Dynomax Bullets: http://laneswheels.com/f1_cammed.mov
Video of True Duals with Flo Pro Twisters:
http://laneswheels.com/12inch_flopro.mov
I wonder which would give more hp.
Old Jan 13, 2004 | 04:20 PM
FacelessZ's Avatar
They're supposed to be quieter than Bullets...I believe they come in 12" and 17", but I could be wrong...
Old Jan 13, 2004 | 04:22 PM
Cmr0z28's Avatar
Hey Grip what's up. Why are you looking to ditch your current setup? Just wondering.....it sure is sweet sounding.
Anyways I think I would give those Flopro's a shot because they're longer and would probably be quieter when cruising without sacrificing performance.....damn those LS1s sound mean.
Old Jan 13, 2004 | 04:27 PM
I'm just changing the mufflers.
I have dynomax Super Turbos. They have 2 u-bends inside (Like an "S" shape) and they're very restrictive.
I've been told going to a bullet muffler with my setup would be a significant gain in horsepower.
Old Jan 13, 2004 | 04:45 PM
got_hp?'s Avatar
heres some proof for ya that the super turbos are restrictive..........check out the CFM in the thread on ls1tech
unfortunately the twisters arent listed in the comparison, and neither are the dynomax bullets.
Old Jan 13, 2004 | 04:52 PM
Cmr0z28's Avatar
Oh.....what about Hooker aerochambers? You can see straight through them....
Old Jan 13, 2004 | 04:57 PM
got_hp?'s Avatar
they placed in the middle of the pack........hookers own maxflow muffler outperformed it by far
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
Old Jan 13, 2004 | 05:31 PM
Cmr0z28's Avatar
Ah ok....
Good info!
Thanx.
Dynomax' website says there is even a bigger difference between super turbos and their bullets.
Old Jan 13, 2004 | 06:57 PM
got_hp?'s Avatar
Good info!
Thanx.
i would assume the bullets flow pretty damn high, and close to a straight pipe..........i bet youll notice some extra power on your 383
Old Jan 13, 2004 | 08:17 PM
revtime's Avatar
I have a pair of Lowbaks sittin in the garage they are the same as those twisters inside, I am going to install them next month so I will let you know how they work out.
Old Jan 13, 2004 | 09:09 PM
Any guess-timates on hp gain?
Old Jan 13, 2004 | 09:12 PM
got_hp?'s Avatar
theres really no way to tell, you just gotta do it!
Old Jan 13, 2004 | 10:10 PM
I'll post dyno results before and after the swap in April.
Old Jan 13, 2004 | 10:20 PM
2cub49's Avatar
I put one before the axle to quet down my Magnaflow. Worked pretty good. Took the drone out at part throttle. Definately quieter than regular bullets.
