flexplate removal
Old Sep 19, 2010 | 07:48 PM
bolek's Avatar
flexplate removal
Are there any tricks or tips to remove a flexplate.
Mine is stuck pretty good.
Old Sep 19, 2010 | 09:15 PM
94EvilZ28's Avatar
Get a long breaker bar 1/2. Get someone to use a pry bar to hold it in place and it should break loose. If not...take a torch and heat em up...if no torch...go ghetto like I did and use a bbq lighter and hold it on there for awhile then use the breaker bar.
Worked great for me...good luck.
Old Sep 20, 2010 | 02:00 AM
MikeGyver's Avatar
The 6 flexplate-to-crank bolts are 'stuck'? you mean they're... tight?
Old Sep 20, 2010 | 06:15 PM
bolek's Avatar
No, not the bolts, but I got it off.
greenzee28
Sep 25, 2015 04:29 PM
wbspoon
Sep 19, 2015 08:12 AM
marlar98
Sep 19, 2015 07:53 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
