Flexplate for internally balanced LT1?
Old Jul 18, 2004 | 08:21 PM
ddr698's Avatar
Does anyone make an SFI flexplate for an internally balanced LT1. All I can seem to find are flexplates for externally balanced 86+ motors. Anyone know? A part number would be great as well! Thanks,
Dan
Old Jul 18, 2004 | 09:04 PM
dreamer1q's Avatar
Re: Flexplate for internally balanced LT1?
Just buy a SFI plate and have a machine shop neutrally balance it for you. It is the accurate way to do it.
Old Jul 18, 2004 | 09:08 PM
1984camaroz28's Avatar
i have one that came with my rotating assembly but i need a flywheel that is netural balanced
Old Jul 18, 2004 | 10:57 PM
1racerdude's Avatar
The people who balance it can 0 balance the flex plate then complete the internal balance of your engine.You can get a SFI balancer for your engine and they can do the same thing,weather the new balancer is internal or external balance.
Old Jul 19, 2004 | 12:53 AM
cliff929's Avatar
ATI makes one for the one piece rear main seal. I think it is the only one. It is 180.00 The part number is 915533 It is an ATI flexplate. you can get one from SDPC 1-800-456-0211 They sell them 10.00 cheeper that ATI.
Old Jul 19, 2004 | 08:44 AM
Revolutionary's Avatar
You can drill or grind the spot welds on the weight welded to your flexplate and remove that weight then have a local shop spin it up for you to check balance.
HectorM52
Jul 30, 2017 11:46 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
