Flexplate for internally balanced LT1?
Does anyone make an SFI flexplate for an internally balanced LT1. All I can seem to find are flexplates for externally balanced 86+ motors. Anyone know? A part number would be great as well! Thanks,
Dan
Dan
Re: Flexplate for internally balanced LT1?
The people who balance it can 0 balance the flex plate then complete the internal balance of your engine.You can get a SFI balancer for your engine and they can do the same thing,weather the new balancer is internal or external balance.
ATI makes one for the one piece rear main seal. I think it is the only one. It is 180.00 The part number is 915533 It is an ATI flexplate. you can get one from SDPC 1-800-456-0211 They sell them 10.00 cheeper that ATI.
You can drill or grind the spot welds on the weight welded to your flexplate and remove that weight then have a local shop spin it up for you to check balance.
