flexplate install question
Old Sep 8, 2004 | 03:43 PM
POLOVETTE 94's Avatar
I just got my ATI neutral balanced 153 tooth flexplate, for my internally balanced 383 LT1. How important is the guide/alignment pin? The engine builder didn't install a new one. Should I use the old one, or is it just there for the people at the factory to throw it on quicker and not put a bolt in the wrong hole? I mean, the center is hubcentric (tight) on the crank, so as long as I put the 6 bolts in the right 6 holes on the flexplate and the crank, does it really matter if the guide pin is in the other hole?
Old Sep 8, 2004 | 11:13 PM
OBE1 95Z28's Avatar
Re: flexplate install question
If the rotating assembly was balanced without the pin, I wouldn't install it. Just be sure the flexplate is bolted on with the holes for the guide pin lined up.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
