Flex Hone size
Old Dec 22, 2008 | 12:10 AM
Rich2279's Avatar
Flex Hone size
Still a little unsure about the flex hone size to use on the cylinders. Talked with a guy who sells them on ebay. I asked what size hone would I need for a 350 Chevy (4" bore). He is suggesting that I purchase a 4 1/8" hone even though I expained that I'm using new rings w/ the original standard pistons. I thought that I would need a 4" bore size hone?
Old Dec 22, 2008 | 08:48 AM
cnorton's Avatar
You might benefit from directing that question directly to:
<http://www.brushresearch.com/>.
I have found them to be very helpful in the past.
Good luck,
c
Old Dec 23, 2008 | 05:00 PM
Rich2279's Avatar
Brush research contacted me and said that the flex hones are made slightly oversized for the cylinder size. So if you have a 350 4" bore, then you would order their 4" hone.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
