flamable heat wrap.
Old Jul 17, 2004 | 02:43 PM
94NDTA's Avatar
flamable heat wrap.
I bought some to cover my fuel lines and a few wires. I have been told metal fuel lines won't be affected by being close to exhasut. I did a lighter test and the tape caught on fire. Is this allright? It is specifically designed for fuel lines and wires, and the guy at the shop said it's the best stuff they have. Should I use it or no?
Old Jul 17, 2004 | 04:24 PM
94NDTA's Avatar
m'kay
Old Jul 17, 2004 | 07:11 PM
94NDTA's Avatar
Old Jul 17, 2004 | 09:24 PM
CCCCCYA's Avatar
Re: flamable heat wrap.
Why bother with the fuel lines? They are pumping 45 psi worth of fuel to and from the tank continuosly, and not picking up much heat (they'll pick up more while in the fuel rails than while they are in the lines on our cars).
As to the lighter test... You can't compare an open flame to a radiant heat source. Apples and oranges as far as flash point is concerned. Also, that cig. lighter can produce around 1100 to 1300 F! WAAAY more that your likely to see coming off an exhaust manifold.
Dave C.
Old Jul 17, 2004 | 09:32 PM
94NDTA's Avatar
Thanks for the reassurance Dave.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
