FIXED!!!!!!!!!!! Well, almost.....
Old Nov 7, 2003 | 06:05 PM
Fastbird93's Avatar
Talking FIXED!!!!!!!!!!! Well, almost.....
After running like extremely rich poop since August (with a six week break while I deployed), sputtering, missing all over the place, making my eyes tear up, and surviving my first opti swap, which WASN'T THE PROBLEM like I thought, my car is fixed.
I swapped the computer from my purple car into the black one. Turned the key and she roared to life. No smelly, no miss.....tap the gas and I thought she was going to jump right off the jackstands up front. Stomped on it and it just revved up like there's no tomorrow. I'm all smiles and giddy right now!!
I didn't throw a code, and the scanner didn't show anything, but I'm under the assumption that it's the same problem that 12SCNDZ had: Quad Driver Module failure.
Now, I need to find a 93 PCM ASAP. If anyone has a lead or anything, hook me up!!!!
Next up: 1.7 rockers......
To be continued............
Old Nov 7, 2003 | 06:09 PM
Stoopalini's Avatar
Glad to see you got it figured out!
Good luck finding the PCM, wish I could help .....
Thomas.
Old Nov 7, 2003 | 09:19 PM
stereomandan's Avatar
Great to hear. You have different cams in the two cars right? Have you taken it off the stands with the other PCM and given it a run? Just wondering how different the two tunes are.
Good luck with your search.
Dan
Old Nov 7, 2003 | 09:46 PM
Fastbird93's Avatar
Stereomandan,
You'd be correct. The black car is 224/230, and the purple car is a hotcam. The black car, before the fix, felt WAAAAAY stronger than the hotcam car. I've got a bead on a new PCM on ebay, so if all goes well I should be working on the tune of the car again, possibly dynoing at the end of next week. If the tunes right, I should be about 375-380 RWHP and 365-370 RWTQ. Maybe a little more even. Unfortunately, My Epromer5 chip burner quit making good chips, so I have to resort to mail to get my new ones. I can say that the two tunes between the cars is very different, if that's what you're asking. The heads on the black car are as good as it gets for a set of stock ported heads, while the ones on the purple car are a lot more mild.
Old Nov 7, 2003 | 10:50 PM
Red_94Formula's Avatar
yea dont romp on the gas when on jack stands. I did that and the damm car almost fall off them.
Old Nov 8, 2003 | 01:21 AM
BBoyce's Avatar
Glad to hear you got it running again.
BTW, who does your chips?
Ben
Old Nov 8, 2003 | 08:30 AM
Fastbird93's Avatar
PCMForless. He does great work, almost nailed my cars tune the first time.
FYI, I know that Madwolf does really good work for 93's too.
Old Jan 21, 2004 | 01:20 PM
Chris 96 WS6's Avatar
Congratulations, I know you are relieved to have the problem behind you.
Old Jan 21, 2004 | 01:24 PM
Fastbird93's Avatar
I should have deleted this thread.
When I swapped the computers the car was cold, hence no problem noted.
I got another 93 PCM, and same stuff still happening.
I'm still in the same boat as you chris.
I can't believe this was dug up!!!
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
WobblySausage
Oct 7, 2015 02:44 PM
Fatdog2
Sep 16, 2015 11:04 PM
Aaront810
Sep 11, 2015 11:24 AM
