fixed my rough idle, thanks guys!
I was gonna change my spark plugs until I found out the plugs are $6 a piece and the parts guy told me it was probly a sensor since the ses light was coming on. He said there was a sensor other than the coolant one that measures temp. Then I remembered reading about people that changed there IAT sensor and got rid of a rough idle/ low rpm hesitation. I was having that problem and the new sensor seems to have cured it
So thanks again, you guys rock!
"I was gonna change my spark plugs until I found out the plugs are $6 a piece and the parts guy told me it was probly a sensor since the ses light was coming on. He said there was a sensor other than the coolant one that measures temp"
Buy a Chilton's Manual ($30) ... it will save you from doing guesswork. When ever there is an SES light on it's usually triggered by a sensor with the ability to be checked for failures by the PCM reading it's values. Things like the Opti, Coil, Fuel Pump and Plugs can't send SES signals......
slothgrant
Aug 22, 2002 03:01 PM
