fixed hard starting problem
Old Oct 3, 2003 | 10:11 PM
95dzz28's Avatar
Hey everybody,
Had a hard starting problem after I ran out of gas. Took 5-10 seconds of cranking before starting. Fuel pressure gauge showed 42 psi during priming, but would immediately drop to 0 when I turned ignition off. Car ran fine otherwise. Replaced fuel pump and solved problem. Now maintains 42 psi after I shut it off. Used the access panel cutout method and made things much easier. Thanks to all who replied to my original post.
'95 Z28, stock, black, M6, T-Tops, graphite cloth interior, 86,000 miles, ordered July '94, manufactured 12/94, purchased 1/95, still enjoy it as much as the day I bought it
Old Oct 3, 2003 | 10:23 PM
Hyperspeed97z28's Avatar
How hard was it doing it by the access panel?
Old Oct 3, 2003 | 11:13 PM
95dzz28's Avatar
Hey Hyper,
It was a heckuva lot easier than dropping the rear axle, exhaust, etc. I guess it took me about 4 hrs., being careful with everything I did. I could probably do it in an hour now.
I used this site for reference--http://www.worldisround.com/articles/12533/index.html
I ended up cutting it closer to the front, probably 1 3/4" (he suggests 2 1/2") and also cut more out of the left front to access the quick disconnects easier. Used a Roto Zip cutout tool with a right angle attachment so it was like using a circular saw with a metal cutting blade. Made short cuts to keep the sparking to a minimum.
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
slothgrant
Aug 22, 2002 03:01 PM
