Fix that water pump shaft leak for good!!!
Old Mar 24, 2011 | 07:58 AM
  #16
pizzi-man's Avatar
Re: Fix that water pump shaft leak for good!!!
Originally Posted by brianswimmer23
nice. not a bad idea, i thought about going with the elec h2o pump but for now its not leaking so i wont need to fix whats not broke.
x2
Old Aug 10, 2011 | 10:39 AM
  #17
TIIMuch's Avatar
Originally Posted by pizzi-man
x2
X3
Thanks, this is good.
Old Aug 10, 2011 | 11:26 AM
  #18
If you install the seal correctly, it doesn't leak.
Old Aug 10, 2011 | 12:01 PM
  #19
DAVE00's Avatar
+1 - ShoeBox is absolutely correct. It's difficult to install, but when it's done right ZERO leaks. Took me 3 tries til I got it right but haven't seen a drop in 3 years.
Old Aug 10, 2011 | 01:27 PM
  #20
94_6speedZ's Avatar
Unless its the water pump drive shaft.
My car leaked oil from the seal when i bought it. After replacing it 3 times over two years it kept leaking. I finally took it to a friend who knows LT1s very well and works as a tech at a chevy dealership. He replaced it himself and again it leaked. Turned out to be the water pump driveshaft was worn out and wobbled slightly enlarging the seal.
Put a new one on and i have been oil leak free for 5 years
Old Aug 10, 2011 | 05:08 PM
  #21
You are right. No amount of correctly installed seals will fix that problem, but it was not the fault of the seal or it's install.
Old Nov 25, 2011 | 03:52 PM
  #22
2QUIK6's Avatar
Originally Posted by TT350
How about a dab of grease.
It was lubed on install, every time.
I'm almost certain there is an insert page that comes with the seal that says to NOT lub the seal to install it dry.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
