FIX: for scanning and tunning with no serial port
Old Mar 14, 2003 | 10:06 AM
  #16
97Z-M6's Avatar
Originally posted by AirForceAMMO
Just some FYI for you folks trying to save a buck on this. Buy the 60 dollar one. If you get a cheaper one to somehow work and it locks up while you are programming, Your PCM could be severly damaged. A 60 dollar adapter is a lot cheaper than a new PCM.
yep its worth the extra 30 bucks
Old Mar 15, 2003 | 03:34 AM
  #17
TriPinTaZ's Avatar
http://www.bestbuy.com/detail.asp?e=...t=567&scat=574
Anyone know if this will work? Much eaiser having a cable instead of a big bulky belkin adapter to fiddle with.
Old Mar 15, 2003 | 10:57 AM
  #18
AirForceAMMO's Avatar
Try it at your own risk. A few people I have talked to have said that those little cables don't work with some laptops and some do. As I said in my last post, you have to ask yourself if its worth the risk of frying your PCM. Some of these cables will cause the program to lockup. During an upload of a program, if the program locks up, You PCM could be severly damaged. Can you afford to go out and get another one? I am not trying to belittle you, just providing you some information that may be helpful.
Old Mar 15, 2003 | 12:25 PM
  #19
Josh-'04 GTO's Avatar
Ran into the lack of a serial port problem myself. The Belkin serial to USB adapter was $30 at Circuit City and works great.
Old Apr 9, 2005 | 03:23 PM
  #20
TA Dreaming's Avatar
Re: FIX: for scanning and tunning with no serial port
ok im gonna resurect this because its news to me that you can tune through the USB port.
ive got a dell with xp pro i think. its xp for sure. ive got both a USB port and a serial port. are there any advantages to using one port over the other? im not a comp savyy person really. so i dont know if somehow the usb is more stable or anything like that. i have only a preference to use the better of the two based on price and or performance. so which would be better to use? thanks
Old May 5, 2005 | 06:28 PM
  #21
RobbyRob's Avatar
I have to put xp pro on my new laptop. Right now I have xp home and it won't run datamaster.
Old May 5, 2005 | 07:19 PM
  #22
ktg's Avatar
ktg
I use a Keyspan serial adapter and it works fine with mine.
Old May 6, 2005 | 09:26 AM
  #23
rob97ss's Avatar
this post couldnt have come at a better time,i just bought lt1 edit,brought it down to the shop that was going to tune my car and he couldnt get it to read the pcm so i will have him look into this adapter
sleeperZ96BT
Sep 9, 2015 08:28 AM
bunker
Aug 21, 2015 10:21 AM
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
