Fittings for oil pressure switch
Old Mar 14, 2014 | 04:08 PM
93Z28Sam's Avatar
I lost the two small fittings for the oil pressure switch on the back of the engine. I have a part number for them but I haven't been able to find them. Does anyone know a place I can get these from? Or an aftermarket part number or manufacturer that might have something that might work. Any input is greatly appreciated, Thanks.
Old Mar 14, 2014 | 05:15 PM
Re: Fittings for oil pressure switch
Did your 93 have the oil pressure sensor on top/rear of the block? Most 93's, and even early 94's have it above the oil filter.
Shoebox has a part # list:
1993-1997 F-Body Part Number Collection
that shows the angle fitting as: 10137636
Is that the same # you have?
http://shbox.com/1/op_sensor.jpg
Old Mar 14, 2014 | 10:00 PM
You can use any similar brass fitting or combination of them that you can get at a hardware store.
Old Mar 15, 2014 | 04:11 PM
93Z28Sam's Avatar
Thanks for the replies, it's a 93 with the switch above the oil filter. I just don't like it been so close to my headers, so I relocated it to the back of the block but I lost them in the rebuild. I do have the part number for them from shoebox website but are very difficult to find. I have an idea about those angle brass fittings I will give them a shot.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Z28countrymama
Jan 22, 2015 02:50 AM
phoenix95
Jan 8, 2015 02:44 PM
Jul 4, 2005 05:00 PM
