fitting 8.8" fo*d rear end in a 94 Z
Old Apr 13, 2003 | 01:56 PM
Abdullah's Avatar
fitting 8.8" ford rear end in a 94 Z
i think it is doable? right? what is needed
to make it done correctly? how to check that the 8.8" goemetery after installation is correct for the Z?
Old Apr 13, 2003 | 02:01 PM
Larnach's Avatar
What I would do is cutoff the axle tubes on the 10 bolt, and weld them to the 8.8. Roughly the same width, I have an 8.8 sitting under the lights in my garage waiting to be rebuilt... if you need measurements of the gear casing I can get those to you.
The trouble I see is welding a torque arm mount to the cast housing.
Old Apr 13, 2003 | 02:17 PM
Abdullah's Avatar
Larnash, thanks. i'm interested to know the measurments of the gear casing, but what are they and what i will need them for? also are the 8.8 axle tubes larger in diameter than the 10 bolt's? how about welding the brackets for the springs and shocks will that be easy using the 8.8 axle tubes? what will happen if you weld the torque arm bracket to the cast 8.8 housing?
my friend told me to use the 8.8 rear end of a mercury grand marqeez not the one for a mustang since the one for the grand marqeez almost has the same axle tubes length as the 10 bolt's where the one for the mustang has longer axle tubes.
Old Apr 13, 2003 | 02:55 PM
merim123's Avatar
do a search in Advanced Forum, you may find what you're looking for. I think this was discussed there about 3-4 months ago.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
