Firebird Headlight Stop
Old Nov 30, 2003 | 08:53 AM
Laymaster's Avatar
To those who have fixed it with the nut/bolt combination.
Works fine for me, except when the headlight stays down (off) for about 3 hours or more. Then the headlight gets stuck and doesn't want to come up. I have to manually loosen it a smidge and then the headlight will work fine. Anyone else have this problem?
Old Nov 30, 2003 | 08:54 AM
got_hp?'s Avatar
what is this nut/bolt fix youre talkin about..........i broke mine off.......tried to epoxy it back on, that lasted a week, then broke off again.
Old Nov 30, 2003 | 08:56 AM
Laymaster's Avatar
Well I drilled a hole in the part that had the stop in it. I slipped a nut on there and then had to drind it down because it was too long. Turns out I ground it down just a hair too short so I stuck a bolt on there to act as the stop, and that it does. The headlight motor holds the nut against the plastic/metal part it sticks through.
Old Nov 30, 2003 | 09:34 AM
got_hp?'s Avatar
hmm.....i gotta do that........having one headlight stick up is annoying.
Old Nov 30, 2003 | 10:27 AM
Brent94Z's Avatar
Super Moderator
Use a smaller nut/bolt combo so you can slide some thick rubber tube/hosing over it. The thick rubber tube/hose will help to provide dampening for when the light closes.
Or, try putting the tube/hose over your current setup. What that will do is stop the light a little early AND help provide dampening.
Old Nov 30, 2003 | 10:30 AM
Laymaster's Avatar
Thanks Brent!
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Brake_L8
Jan 20, 2015 09:44 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
