Firebird guys w/ headlight motor probs
Dont these two items look very similar...notice the mounting holes even. With a little wiring they might be an alternative to our headlight motors. Best part is - they're $25!
Here's a stock driver's side headlight motor:
http://store3.yimg.com/I/dpstore_1732_7595002
Here's the motor I found:
http://www.botparts.com/popup_image.php?pID=217
Interesting! And here's a link to the technical details about that motor:
http://www.botparts.com/product_info...roducts_id=217
Anyone care to try it out?? Theres also a matching motor for the other headlight.
Link to second motor, or tech link doesn't work. I like to see what your talking about. Did you switch to a different motor to fix the problem?
Vinny
Vinny
Doh it looks like the site is currently down for maintenence. That stinks. Check back later I'm sure it will come back up.
As far as I can tell, the only thing you'd lose by moving to these motors is the manual **** that the stockers have. The motors are $25, the waterproof electrical connectors are $2.50 (bottom of page), and then a female GM weatherpak to mate with the factory plug (try rockauto.com) and you're set. No permanent modification to your car required!
Brake_L8
Jan 20, 2015 09:44 AM
