finished single plane!!!
Old Nov 9, 2008 | 05:08 PM
transam1577's Avatar
so i just finished my single plane install today.. it is a stock bottom end,cc503,P&P heads 270/210cfm,crane10308-1 springs,1.6 pro mags,42lb injectors,90mm fast tb,a-1000 fp reg.,lt4km,85mm slp maf,ram air,single plane intake w/custom sheetmetal elbow.. the car made 360rwhp & 402rwtq untuned limited at only 5100rpm before going lean..so there was more left in it for sure.. but i have not had a chance to fully tune it yet..i just put the 42lb injectors in the tune so it would run okay.. but i did drive it up the road and i can tell you it has absolutely no torque..lol witch is obviosly cause of being untuned but.. i will be dyno tuning it this week so it will be interesting to see the difference.. any thoughts on what it will make? and does anybody have any experiece tuning the single planes on here? what are the main areas to consentrate on?
Old Nov 9, 2008 | 08:10 PM
SS MPSTR's Avatar
A single plane with a CC503? Why?
Old Nov 9, 2008 | 08:23 PM
i plan on going bigger lol..but i just want to see what i can get out of it with the cc503..since nobody has done it..and to let everyone know cause everyone always wants to know about a baby cam and a single plane.. so we will see what it does..btw im going with a 600lift cam after i see what i can do with this..
Old Nov 9, 2008 | 08:26 PM
mdacton's Avatar
its not going to make anymore power with it until you get in the 600 n/a range....
sorry to burst your bubble.
Old Nov 10, 2008 | 08:33 AM
doug1105's Avatar
Let's see some pictures-
Old Nov 10, 2008 | 02:34 PM
maybe2fast's Avatar
pics!
Old Nov 14, 2008 | 06:18 PM
1-fuel's Avatar
i would like to see some pics.....im doing a efi vic..but not starting it till monday tuesday
Old Nov 15, 2008 | 04:34 PM
Ken95Z28's Avatar
Seems to be a lot of people doing single planes lately.
I'm doing one that's non-efi but using Ron's Methanol Injection System. Should be done with it first of next year hopefully.
Old Nov 16, 2008 | 02:29 PM
SS MPSTR's Avatar
god only knows why...lots of people won't spend the time/money to get what they have running right, but are quick to jump on the bandwagon on the next greatest trick in the quest for power. Not saying the SP doesn't make power up high, but for 99% of the enthusiasts out there, the LT1/LT4/Edelbrock intake manifolds work just fine. That's a lot of work for a novelty piece.
Old Nov 16, 2008 | 05:15 PM
mdacton's Avatar
Old Jan 1, 2011 | 06:29 PM
WS6 TA's Avatar
Re: finished single plane!!!
Does anyone have dyno graphs before and after on a less radical setup?
Old Jan 2, 2011 | 08:28 AM
96capricemgr's Avatar
http://www.ls1tech.com/forums/5929007-post13.html
A LOT of the problem with this mod is everyone wants to use 8500rpm rated intakes on relatively small under 7000rpm motors, pick a smaller manifold and it might actually work as the bench racers suggest it should.
Old Jan 2, 2011 | 06:28 PM
red94chicken's Avatar
Wow. I thought it would be minimal gains on my set lol, and its way more then 360whp.
9t4lt4z28
Oct 2, 2015 10:28 AM
RX Speed Works
Oct 1, 2015 10:19 PM
CARiD
Sep 30, 2015 05:44 AM
Boss002
Jul 24, 2015 10:47 AM
