Finished LE2 Install, Couple of ?s
I finished my LE2 Build. I had just enought time to start it up before I went to work. Car is running good, sounds great. There is some smoke from what looks like it's comeing out from each side of the Headers. I had painted the headers with High Temperature paint. Is it normal for it to smoke after the instal. How long should that take to burn off? The only other problem I noticed was my oil pressure guage was pegged all the way to the right.
it is normal for the paint to burn off - it shouldnt take to long to stop smoking, but you should check oil pressure with a mechanical gauge to be safe before running any longer - could be a bad sending unit, shorted or broken wires
I forget to plug the oil pressure sensor in. I went out thismorning, I cant find the sensor where it comes off of the harness. I hope that paint burns off quick. I ran it for about 5 minutes thismorning and the service engine light came on. I will hook up the laptop and see what codes show up.
Richardan15
May 30, 2015 08:36 AM
Bignasty85
Mar 3, 2015 04:05 PM
