Finding #1 TDC...
Old Nov 23, 2003 | 05:37 PM
  #16
96 WS6's Avatar
Method 2 requires you to do one at a time... Method 3 which is doing each valve one by one doesn't require TDC. Maybe I will have to do it that way. Am I missing something? Without finding TDC, you have to spin the crank until intake valve opens, lash exhaust valve, then spin the crank until exhaust is open and lash intake right?
Old Nov 23, 2003 | 05:51 PM
  #17
gb95zconv's Avatar
Yes , Yes.....Thats the one I am talking about....you know your exactly where you need to be on each cam lobe. Just read the method carefully and apply .
Old Nov 23, 2003 | 05:58 PM
  #18
96 WS6's Avatar
Guess that's how I'll be doing it. Any tricks or is it as simple as I said? Wait until intake is fully open, lash exhaust, then turn crank until exhaust is fully open then lash intake? I remember reading something about having to turn the crank until the valve is almost closed so you make sure the other valve is on the base lobe of the cam? I'm new when it comes to this stuff, mind walking me through it for a couple valves just so I know for sure? I want to get it right the first time
Old Nov 23, 2003 | 06:10 PM
  #19
gb95zconv's Avatar
From the artical I used.....worked the frist time and I havnt touched them since. Real simple.
"Pick a cylinder, any cylinder. Rotate the engine until the exhaust starts to open. Adjust the intake valve. Now rotate again until the intake valve just closes. Adjust the exhaust valve. Repeat for the other seven cylinders."
Incase you care to read the artical :
http://www.gafba.com/articles/article.asp?tid=3
Old Nov 23, 2003 | 06:19 PM
  #20
96 WS6's Avatar
So you adjust the other valve when exhaust is just starting to open and when intake is just about to close? Sorry for all the dumb question. I got sick because I was in my garage for so long trying to get these rockers correctly.
Old Nov 23, 2003 | 06:38 PM
  #21
gb95zconv's Avatar
Thats all you need to know to adj the intake valve......dang dude you need to take a break and have a cold one.
HectorM52
Jun 23, 2016 08:42 PM
Z28Freak86
Apr 28, 2015 10:35 PM
CARiD
Apr 8, 2015 08:08 AM
mattstrike
Mar 11, 2015 07:33 PM
Sarahrope64
Nov 27, 2014 11:17 AM
