Finally Some Dyno Numbers On The 268xfi Cam!!
Old Nov 26, 2007 | 07:37 PM
  #16
sam pace's Avatar
Originally Posted by reamo04
very nice curve! any videos of it idling?
Also, what RPM do you shift at?
Video is here:
http://videos.camaroz28.com/search/2...4401638d07.htm
I usually shift between 6100-6300 rpm.
Old Nov 26, 2007 | 08:26 PM
  #17
Intense_Spence's Avatar
Just had a quick question about your engine. It says you have 6' rods. I know standard 350 rods are 5.7 and 383 guys sometimes go with a 6' rod to reduce the pressure on the cylinder walls. I've never heard of using a 6' rod in a 350 or 355. I didn't even know you could.
Old Nov 26, 2007 | 08:40 PM
  #18
tnmotown's Avatar
very nice numbers. for you and as well for me, a good dyno-tune will bump up those numbers! sounds nice too!
Old Nov 26, 2007 | 10:56 PM
  #19
urbaNHunter44's Avatar
very nice graph, should have good numbers with a full dynotune.
I was considering the 280XFI for my build, but went with a custom instead that was a little more aggressive. Good to see the XFI stuff is putting down respectable numbers.
Old Nov 27, 2007 | 08:20 AM
  #20
Z-RATED94's Avatar
Originally Posted by sam pace
Video is here:
Nice #s. I have to say, our cars sound pretty close to one another, at idle.
Old Nov 27, 2007 | 10:09 AM
  #21
aboatguy's Avatar
Common on a 355 build to use 6" rods, it allows you to use lighter pistons and get the benefits of a longer rod.
Great numbers for a mild cam.
Old Nov 27, 2007 | 10:30 AM
  #22
marshall93z's Avatar
Yes they are!!
Old Nov 27, 2007 | 12:40 PM
  #23
reamo04's Avatar
i cant wait to see what kinda numbers it runs at the track
Old Nov 27, 2007 | 12:49 PM
  #24
I built a 383 motor with 6" rods one time and had to do some clearanceing on the block for the longer stroke. Any clearanceing needed to go to 6" with 355??
Old Nov 27, 2007 | 01:44 PM
  #25
2QUIK6's Avatar
Thats a nice table top curve Sam. Any idea what RPM that dyno run started at? I'm guessing that at 60mph that would be roughly 3000rpm depending on gearing and what gear they are running in...you'd think it would be standard to use 4th on a M6 for 1:1 but I've found different shops seem to do it differently. Looks like 350rqtq across the spectrum is very nice. That spike at the end is probably an issue with the spark wire/rpm reference, have to just chop that off.
And wow, that baby was running lean! Better numbers are sure to come with a tune so I think you are just breaking the ice on its capabilities.
Old Nov 27, 2007 | 04:49 PM
  #26
sam pace's Avatar
None is needed.
Me too. I want to get the right tune and some dr's so It can hook.
Old Nov 27, 2007 | 04:57 PM
  #27
Ray@NitroDaves's Avatar
nice numbers out of that cam...its prrof you don't have to go large to make good power.
but one reason the TQ curve is so flat is the graph is in MPH instead of RPM.
Old Nov 27, 2007 | 05:00 PM
  #28
speed_demon24's Avatar
+ the torque # is a spike, it looks like it made just under 350rwtq.
Old Nov 27, 2007 | 05:33 PM
  #29
sam pace's Avatar
It was real flat around 350 mark then it spiked. I disregarded that spike for a reason.
Old Dec 7, 2007 | 04:59 PM
  #30
Orr89rocz's Avatar
definately interesting numbers for that small cam. this is the second dyno of this cam that i've seen so far and both made very good numbers. i'm half considering a step up to the xfi 224 cam but afraid i wont beable to control the lobes on that cam. they are just way to aggressive over the nose
