Finally Some Dyno Numbers On The 268xfi Cam!!
Old Nov 17, 2007 | 04:20 PM
sam pace's Avatar
A few people pm'ed me about this cam.
I thought I was going to be around 330-340hp.
Man was I off.
Max HP was 370.91 and Max Tq was 384.06 avg looked around 350 for tq.
TQ was REAL flat across the range till the upper end when it got wierd at the end.
The numbers are sae corrected on a Dynojet Dyno.
I was only able to do 1 run because my A/F ration was around 16:1
Time for a dyno tune asap
My scanner is down so I will get the posted graph posted when its up and running.
Old Nov 17, 2007 | 04:56 PM
mrz28 73/97's Avatar
Outstanding numbers what ci is your motor 350 or 383?
Old Nov 17, 2007 | 05:23 PM
sam pace's Avatar
355ci
Old Nov 17, 2007 | 06:20 PM
1989TransAm's Avatar
Very good. Love to see the dyno graph. By the way with that lean of a fuel mixture you will see some horsepower gain with a good tune.
Old Nov 17, 2007 | 06:25 PM
Kurt Crosbie's Avatar
How much porting work was done to those heads? I used a gm847 cam on my 355 setup and put down 381rwhp with no tuning and just a little cleaning done to heads by a friend. Still got 13mpg city (hard driving) and about 27mpg hwy with 4.10's. What are the dimensions of that cam?
Old Nov 17, 2007 | 07:07 PM
SS MPSTR's Avatar
218/224 @ 0.050", .570"/.565" lift, 113° LSA
Old Nov 17, 2007 | 07:39 PM
2QUIK6's Avatar
Wow! Good goin' Sam. I know I had asked you about it..now you got me wishin' I'd put that cam in my TA. That cam idles pretty good too I bet with that LSA and duration, plenty of vacuum of the brakes too.
I'd like to see what it does once you get it tuned and a couple of pulls to see the curve and how it looks down low compared to this LPE 211/219 I have in both the truck and TA now.
Old Nov 17, 2007 | 08:57 PM
sam pace's Avatar
This thread discribes what have been done to the heads with flow numbers and cam specs.
https://www.camaroz28.com/forums/sho...21#post4069721
Old Nov 17, 2007 | 09:50 PM
Thats pretty impressive. I bet it makes quite the sleeper with that cam.
Old Nov 17, 2007 | 09:59 PM
sam pace's Avatar
I surprise alot of bolt on LS1 guys with it.
Especially when you are side by side and slowly pulling away.
Old Nov 18, 2007 | 10:49 AM
I love showing LS1's what I got. Although, I wish I could build an LS1. Its just so much fun to beat them because you know they already know they can beat you.
Old Nov 25, 2007 | 10:20 PM
Orr89rocz's Avatar
wow incredible numbers! what rpm did it peak at?
Old Nov 26, 2007 | 06:36 PM
sam pace's Avatar
My scanner is still down, so I had to use my dig. cam so I could upload it.
Going back on the 30th to get the final tune for my fuel and timing curve.
Here it is:
Old Nov 26, 2007 | 07:10 PM
MeanGreen97Z's Avatar
Holy crap is that torque flat! Plan on pulling any trees out of the ground with that beast?
Old Nov 26, 2007 | 07:30 PM
reamo04's Avatar
very nice curve! any videos of it idling?
Also, what RPM do you shift at?
