Finally repaired blown head gasket
Old Mar 12, 2005 | 07:01 AM
  #16
TQdrivenws6's Avatar
Re: Finally repaired blown head gasket
I will throw 406/360 SAE out there. Stock shortblock cars don't normally see over 360rwtq unless the dyno is showing a flash from a converter.
Old Mar 12, 2005 | 08:38 AM
  #17
BlkLT1Z28's Avatar
I say if its a good day.....406hp and 373tq
Old Mar 12, 2005 | 03:59 PM
  #18
Showme's Avatar
Man, Oh man oh man. This doesn't look good...
390.2rwhp 357.5 rwtq.
The car went to 6.2k rpm. The AFR was between 13.0-13.5 the entire run.
This doesn't make sense.....All I did was fix the blown head gasket, have the pcm retuned, and changed to a 52mm tb. The check engine light has always been on, but never hurt performance. My last dyno was 399 rwhp and about 369 rwtq.
I came home heart broken wondering what the hell went wrong. Well, I have Comp R lifters and when me and friends adjusted the valves, we went by the GM manual and just turned the crank.
I went outside tore off the valve covers and adjusted the rockers with the car running, put everything back together and went for a test drive.
The car pulled like mad and I even chirped 3rd gear (not barked--but chirped). I felt a huge difference and I knew the car was where it needed to be.
I called the dyno up and asked could I come back since I readjusted the valves and he said yes, come on, but I'll have to charge you again. I said OK I'm on my way. End result was.....
403.5 rwhp 373.7 rwtq. Standard
I'm an official member of the 400 club
Now who do I need to mail this $20 to or do I get to keep it myself, LOL
-Tim
Old Mar 12, 2005 | 05:00 PM
  #19
What about SAE? Those are the numbers that most people go by.
Old Mar 12, 2005 | 07:46 PM
  #20
NightTrain66's Avatar
yea, those R lifters are picky about adjustment. If they are a lil off, the #'s always look bad.
Great #'s once they were adjusted properly though.
What where the SAE #'s?
Lloyds Elliott
972-617-5671
Eportworks.com
Old Mar 12, 2005 | 08:20 PM
  #21
slverbullet's Avatar
lol, if i had posted a guesstimate earlier, i would go back and edit my guess so that it reads what you posted.
Old Mar 12, 2005 | 09:25 PM
  #22
Showme's Avatar
Hey guys,
I'll have to get the SAE #s next week. I was sooo glad to see 400 something that it just slipped my mind and I was trying to get the hell out of there before the dyno owner could say that there was a spike or malfunction at the end of the run that caused the numbers to be more than what it should have been, LOL
Blklt1 z28....It appears that you came closest to the actual numbers, but before I confirm that, I'd better get those SAE #s first.
BIG Thanks to Mr. Lloyd and to all that had a part in this project of mine over the years. The knowledge of the people on this board was a tremendous help to me. Keep up the good work
Take Care and I'll post those sae # as soon as I get them.
-Tim
Old Mar 12, 2005 | 10:04 PM
  #23
Showme's Avatar
Correct me if I'm wrong....
I have this other sheet that gives a breakdown of
TIME/RPM/POWER/TORQUE Absolute barametric pressure: 29.68 in.hg.
Vapor pressure: 0.15in.hg. Intake air temperature: 78.8*f Gear Ratio: 51.24 RPM/mph Correction Factor: 1.01 STD.
If this sheet is the SAE correction factor, then my numbers are...
400 rwhp/ 372.7 rwtq. Here again, this in on the other sheet that he printed out for me. If this is not correct, then I'll get the SAE printout next week.
Either way it goes, I'm happy.
-Tim
Old Mar 13, 2005 | 11:10 AM
  #24
Showme's Avatar
I was wrong in the above post. According to a formula (standard rwhp & torque #s multiplied by 0.96=SAE) given to me by a fellow board member (truedualws6), my approximate SAE #s are
387rwhp/359rwtq SAE.......
-Tim....But here again, I'll get the printout next week.
Old Mar 16, 2005 | 03:00 PM
  #25
Showme's Avatar
OFFICIAL RESULTS....
403.5rwhp/373.7rwtq STD....393.7rwhp/364.6rwtq SAE
Blklt1z28, Its seems that you won unless someone can prove otherwise, LOL
PM me and I'll get your info.
Thanks Everyone.
-Tim
Old Mar 16, 2005 | 03:38 PM
  #26
blind527's Avatar
What kind of head gaskets did you use? I'm gonna be buying a whole new round of gaskets/bolts when I get my heads/cam swap. Were you using stock, and were they sealed correctly?
Old Mar 16, 2005 | 05:13 PM
  #27
Loadre's Avatar
409/378 Sae
Old Mar 16, 2005 | 07:56 PM
  #28
Showme's Avatar
Blind527,
I used the Felpro 1074s if I remember correctly. I would have gone back to Felpro '95 Impalla Gaskets (.026" thick), but my heads had to be shaved and I was afraid my compression would be too high if I used them. I think everything has sealed pretty good. I used the ARP head/intake bolts.
Good luck
-Tim
Old Apr 6, 2005 | 02:17 AM
  #29
NoMoreFbody's Avatar
24 Horsepower.....and 56 pounds of torque.....some of the head bolts aren;t down tight enough and the heads going to blow of the block before you hit 2 grand.....
HAHAHAHa
If I am right though...I definatly want me 20 bucks
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
