Finally got some pics up of the 383 Stroker! Beautiful!
Old Nov 12, 2004 | 12:42 AM
  #46
Bryan Smith's Avatar
Re: Finally got some pics up of the 383 Stroker! Beautiful!
Originally Posted by Dave88LX
What year? 2003 or 2004? Did you camp?
Even though we're talking on aim. 2004, didnt camp. </*****>
Old Nov 12, 2004 | 10:55 AM
  #47
Dave88LX's Avatar
Not a problem, let me know if you need anything else.
Old Nov 12, 2004 | 12:38 PM
  #48
RedHottG2's Avatar
Looks great Dave!! hope your very happy down the road with it.
Old Nov 12, 2004 | 05:01 PM
  #49
Dave88LX's Avatar
Good call on the AC hardlines, these are a PITA to get on!!! Hitting my headers.
I'm going to have to massage things a little I think.
Thanks for the reminder...2 hours and polished AC lines later...here I am.
Old Nov 12, 2004 | 05:58 PM
  #50
eagleknight97's Avatar
Just out of curiousity, why did you put the Delteq on the valve covers? Personally, I would put it down by the radiator. I just think that putting them on the valve covers just add more clutter to the engine bay, especially on top of the valve covers.
Old Nov 12, 2004 | 06:55 PM
  #51
unTAmedLS1's Avatar
Hey I gotta 383 that looks just like that Ill get more pics up soon
Motor
Old Nov 12, 2004 | 07:20 PM
  #52
Dave88LX's Avatar
Personal preference I guess...I paid like $500 for the damn thing, I wanted it to be seen.
Old Nov 12, 2004 | 07:37 PM
  #53
Dave88LX's Avatar
Yeah...so...you made me polish the damn AC lines.
http://paradox.shacknet.nu/dave88lx/...l/AClines1.jpg
http://paradox.shacknet.nu/dave88lx/...l/AClines2.jpg
Old Nov 12, 2004 | 08:07 PM
  #54
IrocSS85's Avatar
just take the butt end of the hammer and push down on the line to give ya about 3/4-1" clearance between the header pipe and the a/c pipe. what is your procedure on polishing the lines? whatever it is it worked really good. do you have a polishing wheel or what?
Old Nov 13, 2004 | 11:04 AM
  #55
Dave88LX's Avatar
I used some of Turtle Wax's Polishing Compound on a rag (green container) then followed up with some "Blue Magic".
Now I gotta do the other line.
Yah I had to unbolt the AC compressor, slide it forward, hook up the lines, then slide it back, and bend the lines slightly forward still. Grrr.
Old Nov 23, 2004 | 09:58 AM
  #56
AlmostfastLT1's Avatar
Hey, I was wondering I am ordering these bushings and as far as the trans mount goes, I have a manual and I was wondering is it universal. Just making sure it will fit on my 6speed for a 94. Also, I am running the bmr k member and not too sure which motor mounts to get, not wanting to go to solid, but I assume I still use the factor mounts and insert poly?
thanks Mark.
Thanks! Yeah it's not too bad here, supposed to get down to 36* tonight though!
It's not the LTCC, but Delteq. It still uses the Optispark, but only for reference of crank (cam? whatever) position for timing. That signal is sent to an ignition module that's sitting under the coil packs on the valve cover.
Thank you! What I did was glass bead it first, then I hit it up with a wire brush on a drill, really brought out the shine!
I got the bushings from Thunder Racing, Prothane brand. See if this link works:
http://www.thunderracing.com/catalog...&vid=4&pcid=92
47-19-409 Prothane Polyurethane Front Swaybar Endlink Kit , 93-02 F-body $13.99
47-7-1136 Prothane Polyurethane Front SwayBar Bushings, 30mm, 93-02 F-body $12.99
47-7-1604 Prothane Polyurethane Transmission Mount, 67-02 F-body $22.99
47-7-1609 Prothane Polyurethane Torque Arm Bushing, 82-02 F-body $14.99
47-7-227 Prothane Polyurethane Front Control Arm Bushings, 93-02 F-body $29.99
I got the motor mount from Auto Zone, Energy Suspension I think it was, for around $25 if I remember right.
Thanks for the comments guys!
Old Nov 24, 2004 | 01:10 PM
  #57
ttt
Old Mar 7, 2005 | 05:33 AM
  #58
Dave88LX's Avatar
Hey Mark, correct (Even though I'm probably too late now). Your drivers side upper motor mount (clamshell) is rebuilt with poly inside and it comes with new bolts to bolt the thing back togother. The passenger side on the BMR already comes with a poly or rubber in it, and you bolt your passenger side solid upper to that. I wanted to go solid on the drivers side, but I couldn't find what I was looking for.
The tranny mount should be universal, but mine is a 6-spd as well so it should work just fine for yours.
I have so many damn pics, I really need to build a webpage for them all.
Here are some more recent pics with the new 5.1 Mpixel cam.
http://paradox.shacknet.nu/dave88lx/...ll/cradle5.jpg
Yes, definitely need to clean up the accessories.
http://paradox.shacknet.nu/dave88lx/...ll/cradle8.jpg
http://paradox.shacknet.nu/dave88lx/...l/install7.jpg
Old Mar 7, 2005 | 10:13 AM
  #59
SS MPSTR's Avatar
Dave,
What is the dealio with your engine now?
Old May 20, 2011 | 08:50 PM
  #60
Dave88LX's Avatar
Originally Posted by shoebox
The longest rebuild in history finally begins the home stretch!
Looking through some old threads. Damn Rob. I like how in 2004 you called it the longest rebuild in history.
Too bad my old hosting is down.
D1SC383LT4
Jan 1, 2016 01:56 PM
Rde Bandit
Mar 21, 2015 10:17 PM
maybe2fast
Mar 13, 2015 11:48 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
