Finally gonna try to fix it.... need some help
Old Sep 13, 2004 | 04:00 PM
lt1powerd's Avatar
Since the day ive had my formy (bout 1.5 years ago) its had a high rpm misfire when it gets hot. When i first got it, we gave it a good tune up: plugs, wires.. basically the works. Since then we've fixed the intake manifold leak, and ive replaced the coil, O2 sensors, and fuel pump, but im still getting the bad miss. After the car warms up for a while, it will start to miss at high rpms, and as it gets hotter, it will begin to miss at lower and lower rpms, all the way down to about 4k. I had been ignoring it, but recently the car doesnt seem to be running right at any rpm.. kinda like its not running at full power like it should. I'm thinking opti, but i wanna make sure thats it before i drop all the cash on a new one since im a poor college kid and have to spend wisly any help is appreciated
Old Sep 13, 2004 | 09:09 PM
Josh-'04 GTO's Avatar
Re: Finally gonna try to fix it.... need some help
My opti did the same thing to me...high rpm misfire. Give Dal a call. I got my opti for less than $200.
Old Sep 14, 2004 | 12:55 PM
TransAmGT94's Avatar
Yep sure does sound like an opti mine did the same thing but it sure didnt last a year and a half
Old Sep 14, 2004 | 01:24 PM
FastZinTennessee's Avatar
I know the opti gets blamed for a lot of things, but mine did almost the same thing. Misfire only at high load, which got progressively worse. However, mine got progressively worse over a few weeks instead of over a year like you.
Old Sep 14, 2004 | 07:03 PM
popsz28's Avatar
before i went threw the exspence in changing the opti i think i would replace the ignition control module
Old Sep 14, 2004 | 07:10 PM
Not likely. In most cases, if an ICM is bad, you simply have NO spark and the car doesn't run.
KYWes
May 22, 2015 08:48 PM
C6LS3
Apr 15, 2015 09:50 AM
squarehead
Nov 21, 2014 08:02 PM
madman69
Aug 18, 2002 03:58 PM
Dragonballz28
Jul 25, 2002 03:19 PM
