Finally! THE DAY HAS COME!
Old Nov 26, 2003 | 07:35 PM
Heatmaker's Avatar
Advanced Member
Talking Finally! THE DAY HAS COME!
HOW YOU LIKE DEMS APPLES!
Let the HP begain...but how do you wire this darn thing up? anyone got an installpage?
Old Nov 26, 2003 | 08:10 PM
drewstealth's Avatar
It looks like a real nice peice. I'm surpised that it didn't come with installation instructions though. You would think it would.
Old Nov 26, 2003 | 08:17 PM
Heatmaker's Avatar
Advanced Member
It didn't talk about wiring just about customizing the Fan shroud to fit the unit.
Old Nov 26, 2003 | 08:19 PM
RamAir95TA's Avatar
CSI install.
Old Nov 26, 2003 | 09:13 PM
94GrayV6's Avatar
I thought you didnt have to modify the fan shroud with the CSI...
Old Nov 26, 2003 | 09:18 PM
jasons93z's Avatar
You have to take out the old impeller in the stock water pump so that it can fit, the you bolt it up.
Old Nov 26, 2003 | 09:19 PM
Heatmaker's Avatar
Advanced Member
Meizerres are the drop ins. The CSI you have to do the Cutting and Grinding. Instructions aren't very helpful. Does anyone have a wiring diagram?
Old Nov 26, 2003 | 09:26 PM
94GrayV6's Avatar
Everyone says that since the CSI isn't as tall as the Meziere, you don't have to modify the fan shroud.
Old Nov 26, 2003 | 10:07 PM
Heatmaker's Avatar
Advanced Member
Water pump housing
Old Nov 26, 2003 | 11:32 PM
Buttercup's Avatar
For some reason I'm rather partial to this wiring scheme
http://stevil.easy48.com/AIR-CSI.htm
Thanks Stevil
Old Nov 26, 2003 | 11:33 PM
Buttercup's Avatar
Mine was butted up against the fan shroud so I did remove a little material, fwiw.
Old Nov 26, 2003 | 11:34 PM
93formula's Avatar
no its miezier that you have to cut, not the csi. i have a mezier and a buddy has a csi, mines cut his dropped in.
Old Nov 26, 2003 | 11:46 PM
atljar's Avatar
You people have all your info *** backwards. If you dont know what you are posting, DONT post it.
CSI pumps require modifying the water pump housing. You need to pull out old impellor and cut little tabs so that the pump slides in. NOTHING needs to be done with fan shroud.
Mezeire pump just needs impellor removed.
Mezeire HD needs impellor removed and fan shroud clearanced.
Old Nov 26, 2003 | 11:58 PM
93formula's Avatar
im talkign bout fan shroud. yes the csi will need the water pump housing to be modified, ground. the mezier just needs the impelly taken off.
Old Nov 26, 2003 | 11:59 PM
Heatmaker's Avatar
Advanced Member
DARNIT I CORRECTED MYSELF AND SAID WATERPUMP HOUSING!
Besides some people do end up messing with the fan shroud
