Final word on L67 injectors for LT1
Old Oct 23, 2011 | 02:15 PM
maybe2fast's Avatar
L67 run at 36.5lbs/hr. @ 47-52psi
LT1 run at 24.9lbs/hr. @ 40-45psi?
If I were to acquire a set of 8 running the racetronix 255lph pump and the booster harness, what would I need to tell my tuner the size injector I have?
also do we need to change injector connectors?
Old Oct 23, 2011 | 06:49 PM
Re: Final word on L67 injectors for LT1
You need to give him all the info you posted above re the L67 injectors, plus the manufacturer of the injectors. But injectors are rated at a single pressure, not a range of pressures. Flow varies with the square root of the pressure ratio.
The LT1 injectors are flow rated at 43.5psi.
You might want to just save the injectors for the future, since they aren't needed at this point.
Old Oct 23, 2011 | 08:25 PM
maybe2fast's Avatar
I am installing a cc306 from the cc503, with supporting mods. I think its time for injectors
Old Oct 26, 2011 | 09:22 PM
maybe2fast's Avatar
with the cc306 aren't injectors required?
Old Oct 27, 2011 | 05:22 AM
You should get larger injectors if you go over ~360HP at the flywheel.
ChrisFrez
Dec 7, 2014 06:01 PM
madman69
Aug 18, 2002 03:58 PM
Z284ever
82
Aug 14, 2002 04:06 PM
Dragonballz28
Jul 25, 2002 03:19 PM
