Final flow #'s from my AFR 210's...not to bad.
Old May 10, 2005 | 06:26 PM
CANTONRACER's Avatar
Picked up my AFR 210's today from my local engine shop.
-Lift---INT---EXH
.100--100.3--61.4
.200--165.2--115.9
.300--222.5--154.4
.400--262.5--209.3
.500--289.2--221.9
.600--301.4--235.8
.700--307.5--251.0
Very curious to how this motor will perform with these heads
Thought I would share.
Old May 10, 2005 | 06:41 PM
n2oblkz
Guest
Posts: n/a
Re: Final flow #'s from my AFR 210's...not to bad.
Those look really good. Do you know what size bore that were flowed at and if they used a pipe on the exhaust side? The exhaust numbers look pretty high.
Old May 10, 2005 | 06:55 PM
4.250" bore size
1-7/8" pipe on the exhaust
The exhaust ports are pretty big.
Old May 10, 2005 | 07:28 PM
n2oblkz
Guest
Posts: n/a
Looks Good!
Old May 10, 2005 | 07:31 PM
FastZinTennessee's Avatar
Originally Posted by CANTONRACER
-Lift---INT---EXH
.100--100.3--61.4
.200--165.2--115.9
.300--222.5--154.4
.400--262.5--209.3
.500--289.2--221.9
.600--301.4--235.8
.700--307.5--251.0
Holy s***.
Old May 10, 2005 | 07:32 PM
snakeatinZ's Avatar
good #'s man!!!
Old May 10, 2005 | 07:54 PM
Hybrid86Z's Avatar
those are some badass flow numbers indeed
did you take the AFR castings and have a 3rd party do some more porting on 'em?
i know it's prob a dumb question but i am just wondering
Old May 11, 2005 | 07:11 AM
The heads were originally done by a fellow board member who bought the heads from a shop out in Texas. I bought them and they needed a some work, so my local engine guy cleaned them up and actually got much better low lift numbers by playing with valve angles.
The intake side could easily be opened up to flow more...maybe next time when I decide to go boosted
Old May 11, 2005 | 09:01 AM
RealQuick's Avatar
Nice numbers. Lloyd did an awesome job on my AFR210's that I am using for boost. He used a 4.03' bore and no pipe:
lift.............intake..........exhaust
.200..........143...............103
.300..........204...............141
.400..........247...............173
.500..........281...............198
.600..........308...............219
.700..........311...............227
Seems like more and more of us are getting better flow numbers if we dont use the AFR porting
Old May 11, 2005 | 10:06 AM
Alvin@pcmforless.com's Avatar
Nice!
Old May 11, 2005 | 11:16 AM
n2oblkz
Guest
Posts: n/a
Posted by: RealQuick
Yeah, that's why I bought a set of bare AFR 210's to have ported. I hadn't heard much good about AFR's porting for what you have to pay for it. I would have had a set of stock heads ported by Lloyd or AI before I bought some AFR ported heads.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
surreybrad
Jul 5, 2015 10:36 PM
Potent77
Apr 1, 2015 12:45 AM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
