Final 2.73-3.73 question
Old Feb 6, 2003 | 11:10 PM
Don't Look Back's Avatar
Sorry to be beating a dead horse here...I've been researching this for a while, and I know I want 3.73's in my 95 A4 Z. What I need from you guys is a definitive list of EVERYTHING required to do this. Gears, install kits, PCM reprograms, anything and everything will help.
Thanks,
Keith
Old Feb 7, 2003 | 06:44 AM
IDOXLR8's Avatar
You will need the following:
Gear
Install Kit
Rearend Fluid (don't forget to get additive)
PCM reprogrammed for gear change.
Old Feb 7, 2003 | 09:14 AM
94 NO TOP Z's Avatar
On the gears if you get Strange or Richmond they make 3.73's for your 2-series carrier. If you go to GM type gears they only make 3.73's for 3-series gears... if you go that route you will also need a 3-series carrier and ABS reluctor wheel.
Sergio
Jan 27, 2016 04:27 PM
Dmonty
Jun 2, 2015 11:19 PM
ChrisFrez
Dec 7, 2014 06:01 PM
madman69
Aug 18, 2002 03:58 PM
Dragonballz28
Jul 25, 2002 03:19 PM
