Fight with friend: YOU decide!
Old Jun 29, 2003 | 11:02 AM
95TA8280's Avatar
My friend said there's no way I'll break into the 12s. Here is my set up:
LT4 Hot Cam Kit, AS&M headers, high flow cat, cut out /w flowmasters cat back. pcmforless, TB airfoil, ALP CAI,
Suspension: all BMR- STB, LCAs, PHB, SFCs
It's an M6 with stock gears. What will I run?
Old Jun 29, 2003 | 11:12 AM
Josh-'04 GTO's Avatar
Your friend should seek professional help.
Don't blow the tires off at the line and the 12s should be yours.
Old Jun 29, 2003 | 11:20 AM
besz28's Avatar
tell your friend to sniff himself
Old Jun 29, 2003 | 11:23 AM
Brent94Z's Avatar
Super Moderator
This is borderline tech anyway so lets not get too carried away with the replies or I'll have to close it
I say "boderline tech" because it is really nearly impossible for people to accurately predict a 1/4 run. Sure, people can get close but there are so many variables that the best thing for you to do is just go to the track and see what happens
Old Jun 29, 2003 | 01:58 PM
EricTheBald's Avatar
If you make the 12's with that motor I think you're going to find that the work that payed off for you the most had to do with suspension, tires and practice.
Old Jun 29, 2003 | 02:00 PM
FastZinTennessee's Avatar
If you can drive, 12s are yours.
BTW what does your friend drive?
John
Old Jun 29, 2003 | 02:03 PM
95TA8280's Avatar
I thought 12s would be really easy with the suspension done?
Aren't people with the hot cam kit running mid 12s with similiar mods?
My friend drives a 96ish Eclipse GSX
Old Jun 29, 2003 | 02:30 PM
besz28's Avatar
hey tell your friend if his car gets in the 17's he wins a date with that chick doing that retarded dance in the commercials
Old Jun 30, 2003 | 03:48 AM
Slayn's Avatar
With some drag radials and a 1.9 60' you should get into the high 12's...
With the mods in my sig (minus the 3.73) I ran a 13.1@106 w/2.0 60' not realizing I was actually shifting at 5600 the whole time, (Tach is WAY off) which means from the 1/8th mile marker (When I end up going into 4th) to the 1/4 mile marker I only went from 4100-4600 rpms for half the track, which is conserving over 50hp according to my dyno... hence the gear change since then.
So in summary, with a good launch you should have high 12's...
Old Jun 30, 2003 | 05:03 AM
magius231's Avatar
typically those people running mid 12's or better without heads are getting either good traction, or really really good tuning, and at least moderate traction.
Old Jun 30, 2003 | 07:27 AM
Let me put it a different way...
It's been a long time since I used to frag race on a regular basis but I do remember this for certain:
It's fairly easy to get down into the 14's without paying attention to your suspension.
As you get into the 13's your tires start to be pretty important and your suspension almost as much.
Going into the 12's I specifically remember a LOT of guys having to pay a lot more attention to how they set their suspension is set up.
Reason being, keeping the tire flat, on the ground, and preventing spin is VERY important, otherwise all the horsepower in the world won't help you.
Now, if your car already does a very good job of hooking up, you're ahead of the game.
I think the point I'm trying to make is that a lot of folks forget how important the stuff OTHER than the motor is.
Old Jun 30, 2003 | 07:43 AM
Dave C. '97 Z28's Avatar
You'll run 13.001 @ 110.
-Dave C. '97 Z28
Old Jun 30, 2003 | 09:31 AM
ZZtop's Avatar
"hey tell your friend if his car gets in the 17's he wins a date with that chick doing that retarded dance in the commercials"
HAHAHA! Do you know what an Eclipse GSX is? It is not the typical rice rocket, it is AWD with a turbo. Nothing amazing stock, but much faster than a 17! My buddies with an aftermarket turbo, front mount intercooler, downpipe, exhaust, bov, tunning, etc runs 12.2 on tiny little street tires!
Moral to the story. Dont knock what you dont know, unless of course you were jsut exaggerating. In any case, it's all good.
Old Jun 30, 2003 | 10:41 AM
racindego's Avatar
ZZ, its still a gay car
Old Jun 30, 2003 | 11:34 AM
Brent94Z's Avatar
Super Moderator
Well, guess that means this topic is closed.
95TA8280, I tried to keep this open for you but as you can see, a couple didn't want to keep it tech related. Sorry.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
Bxlt1
Sep 29, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
