few things wrong with the car
Old Feb 17, 2004 | 11:57 AM
Terran2k's Avatar
ok I have a 97 Z, its been having issues, and i want to fix it soon. some of my sympthoms are, horrible gas mileage like 10mpg/city, seems to be down on power...a year ago i could spin my tires from a stop all the way into 2nd, now I can barely spin 1st with the same tires, (its an A4) and she seems to top out at 120 (100% throttle) rpms get up to 5700, but that might be minus a few hundred rpm as my tach is off + 200 rpm or so, stock 3.23 gears...she has been faster than 120 before when I 1st got it. I do 90% city driving and normally I keep the rpm's under 3000. I have replaced coil, plugs/wires, pcv, fuel filter, o2 sensors,used different MAF, test fuel pressure and its okay, it doesnt drop after shutting car off. I have an autotap and i dont see any codes, no knock or missfires or anything. What do you all think? any suggestions as where to go from here?
Old Feb 17, 2004 | 01:08 PM
Vendetta's Avatar
Are you sure she isn't misfiring?
TTT for ya..
Old Feb 17, 2004 | 01:32 PM
djc485's Avatar
have you tried to replace you oxygen sensors? If not give that a try.
Old Feb 17, 2004 | 02:50 PM
Terran2k's Avatar
yep Oxygen sensors were replaced with AC Delco ones. I hooked up autotap and it shows 0 missfires on all 8 cylinders, unless its missfiring and its not registering with the computer. I really am at a lost right now.
smokin25th
Jan 1, 2015 09:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
Hal Fisher
Sep 14, 2002 09:36 PM
