Few problem, Feul pressure regulator?, bearings? Help!
Old Nov 10, 2005 | 04:36 PM
danny525's Avatar
Question Few problem, Feul pressure regulator?, bearings? Help!
Well i just bought a 95 z28, and obviously, im loving it! But it has a few problems and i was wondering if you all have any idea what they could be and how much roughly its gonna cost me to fix. Okay first problem, when starting the car, it turns over for a while like its not getting feul right away. The problem get worst as the gas tank gets lower on feul. And it only happens when cold. I was told by the seller, it was the feul pressure regulator. Is that what you all think it is too? Second issue. As the cars rpms rise, yuo can hear a winding sound that almost sounds like its coming from the dash/ stick shift. It corrisponds with the rpms, and the slights touch on the gas pedal effects the sound? Sounds very much like a bearing, sound is there when car is reved up in neutral as well. Last but not least is in the rear end. Whinding sound as well, guy says he looked at it and its a missing tooth from the spider spindal? How much does all this cost to fix you figure? id appreciate and help i can get! thank you.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
