Fernco/ Slp Smooth bellows ???'s
Old Aug 9, 2003 | 12:59 AM
smacz28's Avatar
Ok Guys.... I did a search but didnt find the answers. I know there is debate over whether or not it is a worthwhile mod but it cant hurt.
Here are my questions?
When going with a Fernco adapter what do you do to make a provision for the opti venting tube????
I have a Z06 85mm MAF will a 3 inch Fernco work or is it going to be too small??
Thanks in advance,
Shawn
Old Aug 9, 2003 | 08:13 AM
97FormulaWS-6's Avatar
I'm using the Z06 MAF with a Fernco piece... and yes.. I would pop a hole into it for the Opti-Venting....
Old Aug 9, 2003 | 08:48 AM
Josh-'04 GTO's Avatar
Yep, just poked a hole in side of the Fernco with an awl, and was able to get a good tight fit with the Opti vent hose.
Old Aug 9, 2003 | 10:16 AM
The 85mm MAF is 3.33" diameter, so you might have to soften the Fernco a little extra - heat it in hot water in a pot. Gonna be a tight fit. For $5 its worth a try.
Rather than poke a hole in the Fernco, I drilled a small hole in the airbox, under the filter of course, and put the right size rubber grommet in there, then put a straight vacuum connector of the right size in it.
Opti vent next to AIR connection on airbox
I need to update that photo.... the AIR connection seems to have lost its hose, and added a 5/8" vacuum cap
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
n2oblkz
Oct 12, 2015 01:53 AM
Bxlt1
Sep 29, 2015 03:18 PM
