Felpro Oil Pan Gasket????
Old Oct 30, 2003 | 10:12 PM
S.J.S.'s Avatar
K guys I got the Felpro gasket kit for my motor. The oil pas gasket is this thick blue rubber/plastic type gasket. It says not to use any type of chemical sealer on it. I was wonder if that meant you still dont put any on the corners???
thanks
Old Oct 30, 2003 | 10:44 PM
PoorMan's Avatar
I have the same gasket. I installed it dry. It hasn't leaked yet. I too wondered about that. I figured "dry" meant "dry" so I didn't use any.
Jeff D.
Old Oct 30, 2003 | 11:59 PM
Lt1t56's Avatar
Used the Felpro gasket myself, put small amount of silicone on the timing cover corners and rear main housing corners also.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
4586
Apr 29, 2015 01:43 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
