Felpro gasket problems?
Old May 10, 2008 | 08:17 PM
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
I have a 96 trans am and just did a LT header job, well tried copper gaskets and they SUCK, then i went and got some felpro 1470 gaskets, and the passenger side gasket sealed up perfectly and the driver side gasket sealed up except the middle ports are leaking, i loosened the header back up and re torqued them and it is still leaking , what can i do, or should i get earls gasket? anyone know what to do?
Old May 10, 2008 | 08:59 PM
Ricardo's Avatar
I use felpro 1406 with HOOKER LT's.
Never had a problem with gaskets leaking.
Maybe your flanges are bent?
Old May 10, 2008 | 09:02 PM
The Engineer's Avatar
Are you sure your header flange isn't warped and that in-turn is causing the problem?
WD
Old May 10, 2008 | 09:04 PM
how would i tell? and how do i fix it? they are brand new pacesetter lts
Old May 10, 2008 | 09:12 PM
mdacton's Avatar
sometimes you can cut the flanges in between the ports.
I always use 1406's...pacesetters are cheap so I would be supprized if it is warped. But it can be fixed easy...you just have to take it back off.
Old May 10, 2008 | 09:14 PM
Ricardo's Avatar
That should be checked before installing the headers. You lay a straight edge all along the flange on the gasket side.
Old May 10, 2008 | 09:37 PM
what do u mean staight edge? im confused? ok and if it is warped then how do u fix it?
Old May 10, 2008 | 09:40 PM
its just the middle ports on the driver side on the bottom of the flange that is leaking
Old May 10, 2008 | 09:51 PM
mdacton's Avatar
take it somewhere and put it on a big *** flat sander
Old May 10, 2008 | 11:16 PM
Dave1980's Avatar
FWIW I heard the same, but checked my pacesetters (still sitting in my room) a while back after hearing that. They came back straighter than straight. I think it is good practice to check stuff like that however.
To the OP I would try the earl crush gasket before pulling it off. I might even have a spare laying around to try it out with, if you pm me.
Old May 11, 2008 | 01:00 PM
pm sent, yeh hopefully i can get a thicker gasket and solve that problem
HectorM52
Jan 30, 2015 11:34 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
