feels like car is missing
Old Mar 16, 2003 | 07:29 PM
  #16
bachehbad's Avatar
same here, this is pissing me off, BIG TIME!
Old Mar 16, 2003 | 08:41 PM
  #17
bachehbad's Avatar
ok just threw in a bottle of fuel injector cleaner, went on the highway and floored it, then drove for a bit ate up a good 10litres... no effect at all, still hesitates and ****
Old Mar 16, 2003 | 11:15 PM
  #18
bachehbad's Avatar
ok did a search and i found ppl whoi replaced there opti got the problem fixed.... anyone replace the opti and find that it worked???
Old Mar 16, 2003 | 11:44 PM
  #19
LS1_03's Avatar
Don't hop straight to the opti. Start cheap, check plugs and wires, coil and coil wire. Possibly the EGR valve. See if your car is throwing any codes. How many miles are on the car anyway? If under 100k the opti should still be good but cars are unpredictable. Just tryin to save you some money instead of you putting down around 200-300 bucks on a new opti and have it not fix it. To make your car run lean, you have to have your car tuned or reprogrammed.
Old Mar 16, 2003 | 11:47 PM
  #20
bachehbad's Avatar
wheres the EGR valve? and what should i check for????
But i'll take your advice and start cheap... ive already changed the spark plugs!
Old Mar 16, 2003 | 11:52 PM
  #21
Dupont24's Avatar
I had the same problems. I replaced plugs, wires, fuel filter, cleaned the air filter, replaced transmision mount(???), and evetually did the opti just so I wouldn't be stuck somewhere. It runs fine now.....but maybe I listed something you haven't done. Oh and I replaced the coil. Hope you find the problem.
Old Mar 16, 2003 | 11:53 PM
  #22
turbo_Z's Avatar
hmm... the problem only started AFTER the plugs and wires were changed. soooo.... im guessing bad plugs or wires. this most definitely sounds like an arching plug wire to me but a bad plug will do the same thing. what you should do is start your car up at night and pop the hood to observe any arching or flashing from the plugs. small glows are nothing... what you are looking for is lightning archs.
remember... just because something is new doesnt mean is works.
Old Mar 16, 2003 | 11:56 PM
  #23
bachehbad's Avatar
oh and i just recently hit 100,000miles
Old Mar 17, 2003 | 12:27 AM
  #24
bachehbad's Avatar
Ok i just found out my EGR was blocked off already! So i tryed unplugging it and putting the other tube back on and nothing changed at all. Now this started after i changed my plugs and fuel filter, now the guy didnt put any of tht non conducting grease stuff on my plugs, could tht be what the hesitation is??? I will go buy spark plug wires tommorow, i just need some recomendations, throw a couple names at me so i have an easier time finding a set.
Old Mar 17, 2003 | 09:24 AM
  #25
Dupont24's Avatar
NGK iridium plugs and MSD wires. IMO
Old Mar 17, 2003 | 07:37 PM
  #26
Twice The Fun's Avatar
to my knowledge MSD wires are a PITA for LT1 stock manifolds..........by the way, replace the plug wires for sure, fixed my problem and the car runs fine!!!
plug wires plug wire plug wires!!!!!
Old Mar 17, 2003 | 09:45 PM
  #27
tkatchev69's Avatar
Well I know for myself, I replaced the plugs and wires with the AC Delco parts. Factory parts usually last a while. But I have the same problem still. It's not the plugs, wires, fuel filter, or air filter. I don't think it's the opti, based on how it's acting. Any more ideas?
Old Mar 17, 2003 | 09:56 PM
  #28
bachehbad's Avatar
Ok guys i had a broken spark plug that was arcing to the engine!!
so check yur plugs all of them! my problem went away and the car drives like brand new now!!!
cmdeshon
Dec 12, 2014 10:51 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
