Fastest LT1
You'd have to specify what makes the car "LT1" powered IMO. Most go to an aftermarket head casting & get rid of one of the physical things many would say makes something an LT1 - the intake manifold. If you're going to another head casting and swapping to a converted supervictor etc., then IMO it's just like any other small block chevy - with the benefit of reverse cooling
Some are running hard with the GM intake, i.e. Mindgame who's posting again, but he does have a converted set of 15deg heads.
SO... it depends on what makes an LT1 an LT1, and if that actually effects it's output IMO
[QUOTE]Originally posted by Metlhed54
in hot rod i think it was they just id an article on the fastest f bodies and i think it was 8.25 or 8.5 but it might have been an ls1 i can't remmeber. [/Q
that was an ls1 but like AI said theres nothin on that car that resembles an ls1 its all aftermarket even the block and heads are c5r
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
ron dukes car is a CR5 block and heads, and went 8.52.
Chris Sikora went 8.96, with an auto and a blower
Joe Overton just went 9.57 last week ALL MOTOR baby!
and an auto
the only thing that makes mine unique is i am still running the original T56 and also the LT1 intake, mine has gone 9.60.
new times a comin'
it is very cool just to be mentioned amongst the faster cars!
and an auto
new times a comin'
"Bullet67 Has These Mods
509 (.030 502 block)Dart 360 heads, 1050 dominator, Isky roller, 12.5 to 1, Turbo 400/w 5700 ATI convertor. Nitrous Express Gemini Quad plate jetted at 250hp"
Damn, I didn't know LT1s were 502ci!
For several years, the top guns in LT1 were Dave "Sled" DeLuca, Brian "Madman" Jeffrey and George Baxter. Sled (N2O) and Madman (ATI S/C) ran low 9.1x, 155's. Baxter (Vortech S/C) ran 9.04@155mph, in a 3,900# 30th SS convertible. That record stood for almost 2 years, until Chris topped it. George's engine made 1,125flywheelHP - engine dyno proven. 4-bolt LT1 block, Canfield LT4 heads, LT4 intake, Hooker LT's, TH400, 9-inch rear.
I think that the informal "rules" (we actually sponsored a "Fastest F-Body" meet) were LT1 block, 23deg heads, stock "style" suspension... all components in stock location, torque arm, etc. No clutchless trannies.
Madman has since switched to a Gen 1 SBC, running well into the 8's., and George has done the same. 383 Dart Iron Eagle, Brodix 23deg heads (limited by PRO/Edelbrock Xtreme Street rules), Vortech S/C. The car has put down over 1,000rwHP, and weighs close to 400# less than it used to. We took it to Steve Spohn's shop on Saturday for some "stock style" suspension tweeks... should hit the track in about 2 weeks. The PRO/Edelbrock class pretty much requires that you run at least 8.40 to be competetive.
I have some pictures of the car and engine available... it still looks like a stock 30th SS convertible, except for a large spoiler and the chute mount. I need clearance from George to post the pictures.
almost forgot about Vince McCauley, he has gone 9.03 or something low low 9.0xx, prior to Chris breaking the 8 second barrier, please someone correct me if I am mistaken. now i gotta check those links, i just think Baxter's car rules!!!
