fans wont come on
Old Apr 29, 2007 | 01:30 PM
95m6z28's Avatar
fans wont come on
ok so i changed my opti and water pump with accel unit the car runs great but fans wont work unless i disconnect my maf sensor ive replacet the rad fan sensor and the coolant temp sensor what could cause this?
Old Apr 29, 2007 | 01:34 PM
What temp is it getting to and do they come on when you turn on the a/c?
Old Apr 29, 2007 | 01:42 PM
95m6z28's Avatar
it gets to about 240ish and no it dosnt turn on with the ac
Old Apr 29, 2007 | 09:10 PM
I would verify the temp reading the PCM sees with a scanner and also see if the PCM is commanding the fans on with the a/c.
Old Apr 30, 2007 | 06:08 AM
sssalah's Avatar
Disconnecting the temp sensor at the water pump should cause the fans to run if fuses and relays are good. Jumpering the 4 and 5 terminals at the DLC connector should do the same.
I've seen this happening several times when coolant is drained and the sensor goes dry that it needs some time before going back to normal.
Old May 4, 2007 | 03:11 AM
95m6z28's Avatar
yall rock thanks for the advice
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
