fans wont come on
fans wont come on
ok so i changed my opti and water pump with accel unit the car runs great but fans wont work unless i disconnect my maf sensor ive replacet the rad fan sensor and the coolant temp sensor what could cause this?
Disconnecting the temp sensor at the water pump should cause the fans to run if fuses and relays are good. Jumpering the 4 and 5 terminals at the DLC connector should do the same.
I've seen this happening several times when coolant is drained and the sensor goes dry that it needs some time before going back to normal.
Formula Steve
Sep 19, 2023 08:31 AM
