Fans squeak after water pump change
Old Oct 21, 2006 | 12:56 PM
Craddock's Avatar
I changed out my water pump yesterday, and I've got some new problems. The old pump was really shot. So we get it in pretty well and now the fans squeak pretty bad. When we first started it up, they squealed like a banshee, even louder than the exhaust and engine. It's not quite as bad now, but it wasn't doing this before the water pump change. We didn't maul the fans as far as I know. They didn't squeak before, but after the change they do. Both fans squeak, I tried them both by hand and they both do it.
So, any idea because this is really embarassing.
Old Oct 22, 2006 | 07:29 PM
Craddock's Avatar
Re: Fans squeak after water pump change
No response at all? Not even any help from Injuneer?
Old Oct 22, 2006 | 07:42 PM
MeanGreen97Z's Avatar
Spray the motors with wd-40. Coolant is not a really good lubricant. Bet it goes away.
Old Oct 22, 2006 | 07:56 PM
Craddock's Avatar
Thank you, I'll try that tomorrow morning.
Old Oct 22, 2006 | 08:00 PM
mmmchickenboy's Avatar
turn the fans by hand and see if you can locate the noise (BE CAREFUL, pull the relays or fuses or something, or the battery cable)
HectorM52
Jul 30, 2017 11:46 AM
grgguy
17
Feb 23, 2015 07:57 PM
MattFick
Feb 15, 2015 10:16 PM
pologreen97z
Dec 2, 2014 10:42 AM
cristian1311
Nov 23, 2014 02:22 PM
