Fans running all the time, AC stopped working?
Old Sep 1, 2007 | 08:24 PM
RyanD's Avatar
My fans are always running and my AC stopped working around the same time? Any recommendations?
Old Sep 1, 2007 | 10:41 PM
Look to see if the SES is on. If so, the fans will normally be on, too. Flash the code and see what it is.
Old Sep 2, 2007 | 09:47 AM
RyanD's Avatar
I flashed the codes, and all I got was 12 over and over. So it's not throwing a code.
Old Sep 2, 2007 | 09:51 AM
foxbat's Avatar
your freon must have leaked out. mine did this too. i had no freon, and my pressure switch was bad.
Old Sep 2, 2007 | 09:59 AM
RyanD's Avatar
Will a bad pressure switch make the fans run the whole time even with the A/C off? Edit: yes it will
Now how do I fix it without fixing the A/C right away? (without programming it out) Any ideas?
Old Sep 2, 2007 | 01:34 PM
According the to factory manual, the a/c pressure switch does not cause a SES light, so I would think the fans should not come on because of it.
Old Sep 2, 2007 | 01:56 PM
RyanD's Avatar
Well, I could always replace my cut a/c hose and see if it helps. How do I go about replacing the hose that runs right next to the alernator? It has some type of crimp connectors on the end that connect to the hardline and I'm not so sure about them?
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
Deadbolt24
Dec 18, 2014 08:18 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
