Fan Switch Question
Old Jun 27, 2009 | 11:58 AM
Zeke28's Avatar
Fan Switch Question
I bought a Jet Fan switch to turn my fans on at a lower temperature. The location that is specified for the sensor is in the passenger side head and there is also a supplied jumper harness that attaches to the sensor.
The location in the head is in an awkward place and the plug that needs to be removed in the head looks like it is smaller than the sensor. I was wondering if I could just remove the current sensor in the waterpump, which is more accessible, replace it with the Jet sensor and dispense with the jumper harness?
Old Jun 27, 2009 | 12:50 PM
NJ-LE's Avatar
Zeke28:
"I was wondering if I could just remove the current sensor in the waterpump"
No, that's the sensor the PCM uses in a number of calculations. It's also the same size as the port in the head ... 3/8 NPT. I think the square plug tool you need for the plug in the head is 8mm.
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
Rich_z28
Sep 8, 2002 12:00 AM
sfGi8nt
Aug 1, 2002 05:54 AM
