Fan switch question
Old Jul 30, 2006 | 07:02 PM
arsss1's Avatar
Fan switch question
Yesterday where I live in illinois it was 98 deg. I decided to install my fan switch. After I was done I go to get in the car to see if everything was working properly. Everyhting works but now my abs inop light is on. Is this normal? It is a virgin 97 m6 that has never had anything wrong. Did I mess something up? Please tell me this happens all the time!
Thanks, Dave
Old Jul 30, 2006 | 07:10 PM
Steve in Seattle's Avatar
Re: Fan switch question
Do you have a burnt out 3rd tail light?
If not... did you cut any other wires than the two signal wires to the fans?
Did you include the diodes?
Check this out: http://shbox.com/1/fan_sw_diagram2.jpg
Old Jul 31, 2006 | 09:08 PM
arsss1's Avatar
I'm sorry, I should have told you that it is an slp fan switch. So there's my problem, all I had to do was unplug and plug in a connector. I sure hope there's nothing wrong!
Thanks, Dave
Old Jul 31, 2006 | 09:24 PM
dannyum89's Avatar
I just installed that switch on my car and didn't get that problem. Maybe something isn't making contact. Take the switch harness off and see if the light goes away.
Old Jul 31, 2006 | 09:38 PM
Did you happen to disturb the connector with the tightly twisted green and tan wires that are near where you plugged in your fan switch wiring?
Old Aug 1, 2006 | 02:16 PM
arsss1's Avatar
I'm not sure if I did or not. If something was wrong, how would I go about fixing the problem? I'm all most positive that the only thing I did was unplug the c100. I will check tonight as soon as I get home.
Thanks, Dave
Old Aug 1, 2006 | 04:35 PM
Thanks, Dave
Maybe you unplugged it. Check it out.
Old Aug 1, 2006 | 09:11 PM
arsss1's Avatar
Where is the plug in for the green and tan wires? Behind the pcm?
Old Aug 1, 2006 | 10:15 PM
IIRC, it's right there by C100 or therabouts. Trace it out.
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
Rich_z28
Sep 8, 2002 12:00 AM
sfGi8nt
Aug 1, 2002 05:54 AM
