fan switch help
Old Mar 30, 2004 | 04:41 PM
a_magoo's Avatar
fan switch help
I have a 96 formula and I used Shoebox's diagram to help me do my manual fan switch. I put in the diodes and resistors but couldn't get it to work. I took out the section of diodes and resistors and it worked, but I got an SES light. What did I do wrong? What needs to be there and what doesn't? I used the diode on each side with two 47ohm resistors on the blue side and one on the green. Any help would be appreciated.
Thanks,
Aron
Old Mar 30, 2004 | 04:42 PM
HBHRacing's Avatar
did you put the diods in the correct direction? how did you wire the resisters? in serise or paralell?
Old Mar 30, 2004 | 04:43 PM
a_magoo's Avatar
I'm not sure on the diodes. The double is done piggyback just like the picture.
Thanks,
Aron
Old Mar 30, 2004 | 04:58 PM
HBHRacing's Avatar
I did my 96 without the LED's as per Robs giude and had no issuses what so ever (after I installed the resisters right that is). you might wanna chack and make sure that you didnlt place a diode in instead of the resister or vice versa and look and see where the line is on th diode, that line goes closer to the switch, it;s make to allow voltage to only go one way and if it;s backwords it will interfer with the power
Jeff'SS
Jun 1, 2015 06:21 AM
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
