Fan Switch????
Screw what resistor to use and go to Radio Shack and get 2 of these . They come in green and red or 2 of these .
Yours is the easy idea though.
Marvin
Originally posted by importeater
Screw what resistor to use and go to Radio Shack and get 2 of these . They come in green and red or 2 of these . They only come in red, they are what I used on mine. I have used both and they are a piece of cake to use and come preassembled with resistors and diodes already built in and has the housing around it for easy mounting. Just drill a hole and slide it through just like the switch. End of story!
Craig
Craig
Is this gonna work on all Z28 cooling fans. I mean are they all 2 speed, Hi-Low. I am not sure if my cooling fans are two speed, hi-low, because when I checked them using the scanner I found out that each cooling fan starts at a different temperature. So, do they go into hi speed later when the temp rises.
this program does it all has helped me many times
Oh wait, I meant to respond to BlueCamaroZ28. The answer is Yes. You will be able to control two speeds. Even if your fans are one speed. Its the way the Fan Driver relays are rigged. I saw one diagram and two fans were controled with two Relays first in series then in parallel. that made the fans work in two speed modes.
Marvin
Originally posted by MentalCaseOne
Nifty little program aint it? Now where can I find one that helps with Hexfets or IGBT junction Temperature Calculations??
Marvin
Marvin
Bless your heart.
Cooling system info
Your LH fan comes on first, at the low temp threshold and the RH fan comes on at the high temp threshold. They already only run at full speed.
Originally posted by shoebox
You have the 2 relay system and not the 3 relay low/high system. Nothing is going to change that unless you add a relay and wiring to make it like the 3 relay system. You really don't need to, though. The fan switch will work fine with either system.
Cooling system info
Cooling system info
That's great info. Thanks Man.
As I read the article, it says "Low speed is less noisy and should result in greater fan longevity. High speed is not always needed."
Is it possible to switch to the 3-relay setup. Would that have a conflict with the PCM if it tries to switch each fan at different temp.
Shoebox,
Shoebox,
IMO, it's one of those jobs that you might do if you don't have anything else to play with.
It probably won't make a big difference as far as cooling goes, but if you want it to be a little quieter, it might help.
Yea you really want the lights. Its cool to see when the computer turns them on. I think its probably one of the best mods ive done so far.
Craig
Craig
thats pretty cool.
I'm going to use the schematic you linked to as well.
Lets hope it all works out good.
Thanks.
brown black black purple gold would be 700 ohm with a 5% variance??? is that how it works?
