False low coolant light
Old Sep 16, 2009 | 07:39 AM
billy-94z28's Avatar
I have a 94 z-28, and getting a low coolant light coming on while driving.
It is false because my coolant level is at the correct point when I check on the coolant dipstick.
Is there a sensor in the overflow bottle that could be bad?
Any suggestions appreciated.
Old Sep 16, 2009 | 09:38 AM
Done a search and found my answer, posted from work, with little time.
The search really is a great feature.
Old Sep 16, 2009 | 09:39 AM
1994 BIRD's Avatar
The sensor is mounted on the radiator behind the battery. You have to drain the water down to change it.
Old Sep 16, 2009 | 10:07 AM
davidz28guy's Avatar
it will probably just go bad again if you replace it, if you unplug it im pretty sure the light goes out, just keep an eye on your fluids
Old Sep 16, 2009 | 10:24 AM
Mikes 1994 z28's Avatar
I think some ppl have had luck cleaning the element and re installing it. Try that before you go out and buy a new one.
Old Sep 16, 2009 | 10:40 AM
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
calaban
May 18, 2020 06:43 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
