False? knock readings
Old Jul 3, 2003 | 03:27 PM
m0nk's Avatar
I am getting knock readings under 2500 rpm in WOT and I have a good feeling they are false. It happens when i run 87 octane, as well as if i run 93. Yet I only have an 8.3:1 C/R so 87 should be more than enough. I had my brother listen in on the block when i was parked and I tapped the gas a few times, and out of 10 times 3 times it detected knock. But my brother listening in on the block heard nothing different, and nothing out of the ordinary. He said it sounded like the engine was running beautifully.
So anyone have any ideas what would be causing my false knock readings?
Or anyone have better ideas as to testing the knock readings?
Old Jul 3, 2003 | 03:36 PM
'94 Bad A Z28's Avatar
I was gonna say LT4 KM, but I see you already have one, lol. Dunno.
Old Jul 3, 2003 | 04:12 PM
m0nk's Avatar
Yea that would have been my first plan of attack, but since I already have it, im lost
Old Jul 3, 2003 | 04:21 PM
The only other thing to do is get it scanned, lol... Or you could, ummm.... confuse the computer, and pad the senser with some tissue. Not the smartest thing to do, but a temporary fix.
Old Jul 3, 2003 | 04:48 PM
m0nk's Avatar
The computer is not throwing any codes, and I just replaced the sensor, because it was throwing the ks code, and that soved that problem, but Im still reading knock when I shouldnt.
Old Jul 3, 2003 | 04:54 PM
I know... The LT4KM dosen't stop all knock readings, lol... It just supresses them... Adding some sort of padding to the KM will do this even more! Like I said though, it's not the smartest thing to do.
Old Jul 4, 2003 | 01:29 PM
m0nk's Avatar
Instead of padding it I think ill just change my knock recovery rate so it recovers faster. I only knock below 2500 when I nail the gas so my only problem when I take it to the track will be in the launch, and if I crank the recovery rate everything should work out.
HectorM52
Mar 15, 2015 10:45 PM
Gtpguy
Jan 26, 2015 04:50 PM
Nostang 96z
Sep 10, 2002 08:54 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
