failed visual smog because of T.B. bypass!!
Old Feb 24, 2005 | 08:41 AM
  #16
CANTONRACER's Avatar
Re: failed visual smog because of T.B. bypass!!
I would have had words with the guy...and spoke with his supervisor about wasting $5 in fuel and an hour of your time all because he is a ****.
Old Feb 24, 2005 | 12:17 PM
  #17
Z06Z28's Avatar
Bud and Demon mentioned checking out the 02's. Remember that your local Autozone store loans out tools so maybe they have a scanner available for you to use. I use Autotap software which comes in handy, too bad your too far or else I would say swing by.
Old Feb 24, 2005 | 02:43 PM
  #18
BlownF1's Avatar
Originally Posted by FULLSLP1
down here in san diego/ carlsbad area...and the only mods that i have on now are.. slp 1 3/4 headers (legal)...i would imagine that the headers wouldn't make the nox go up beyond smog regulation since they are carb legal and as such were tested on a factory stock fuel system...what do you think?
I live in the same area and have the same headers, with a host of other mods and passed with flying colors...only blew 1/3 of one of the numbers, and 1/2 of the other (I don't remember which was which), but I also had a brand new cat at the time. I'd check your O2's and for any vacuum/exhaust leaks.
I also have the TB bypass done and have never had it questioned...legit or not, that's petty of the guy to fail you for. There have been some major crackdowns in the SanDiego area in the last couple years, relating to bribing smog shops to provide phony certs, so he just might not have been comfortable with you or your car for whatever reason.
Old Feb 24, 2005 | 06:05 PM
  #19
1996LT1NY's Avatar
I'd be willing to bet the guy who tested your car the first time gets beaten by his wife... (at least verbally if not physically) & has no other outlet for frustration
Old Feb 24, 2005 | 08:52 PM
  #20
EDS Z28's Avatar
That guy is a ****ing idiot.
I passed also at a test only station, flp long tubes, dual cats, hotcam, blower, and all. I did retain the air pump and egr connections on the headers to make it look legal. The guy was just amazed at my car, he didn't care what I had on it as long as it passed.
The first time I brought it in, it failed miserably, qualifying as a gross polluter. I retuned it, brought it back in and failed again. After that, I took the exhaust off (edelbrocks) to find a broken up cat converter. Probably from running my motor in open loop all the time. I then installed the flp's and it passed with flying colors as mentioned above.
Old Feb 24, 2005 | 08:53 PM
  #21
FULLSLP1's Avatar
now when i threw the headers on i changed the o2 sensors in the headers the Ho2 sensors. so i assume that if 2 of the four sensors had a problem then the other 2 would be a reference to the ecm and throw an o2 sensor malfunction code. and since i change both the heated o2 sensors with my headers 1 year ago(1,300miles) that they should all be working right. did i explain that correctly!
Old Feb 25, 2005 | 08:08 PM
  #22
FULLSLP1's Avatar
ok so i'm driving this morning and scanned my ecm and found my (HO2 sensor right bank #1) code displayed but no ses light...like i said the front two ho2 sensors were replaced 1 year 1,300 miles ago(bosch) is it malfunctioning and if so why wouldn't the ses light illuminate? thanks again.
Old Feb 25, 2005 | 08:22 PM
  #23
Fuels94TA's Avatar
I see many post that bosch are crap. Stay with oem ac delco.
Old Feb 25, 2005 | 08:26 PM
  #24
EDS Z28's Avatar
Bummer I noticed you have OBD 2. That is much harder to pass with mods than an OBD 1 car in CA due to the extra 02's and computer monitoring the effectiveness of the cats.
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
damnyankee36
Sep 9, 2015 07:06 PM
