Failed smog, need help plz
Old Oct 31, 2003 | 07:15 AM
acid5868's Avatar
Well I finally went to smog my car due to registration. Anyways it failed. The reason I failed were due to the following:
The following monitors were not ready: 3
Catalyst
EGR system
Oxygen sensor heater
From what I know it looks like if I replace my rear O2 sensors and the egr valve I should have no problems. Am I wrong to assume this? If so I have no clue what could be causing this issue. I do know that I get the dreaded EGR code thrown and I have had I think its code # P0171 for lean on bank 2 but haven't seen it since. I really don't want to take the car to the dealership to have them fix it as it would probably be an arm and leg in price.
Btw the car is in stock form, but has good plugs, wires, and coil. Any ideas?
Old Oct 31, 2003 | 10:01 PM
acid5868's Avatar
ttt...anyone have any ideas?
Old Oct 31, 2003 | 10:53 PM
Fatdog's Avatar
Cool
From what I've heard,Change the oil(first thing),then change the plugs.Make sure the motor is real hot(the smog sniffer likes a hot engine),don't just drive to the place with a cold car.Let the car sit in the parking lot and idle,let it get so hot as to make the fans come on.Then roll it into the smog check.Never do a smog check with a cold engine(open loop).Hope this helps.
Old Oct 31, 2003 | 11:44 PM
acid5868's Avatar
Thanks for the respone. Unfortantely I can't seem to find a place that has the old equipment. Everywhere I go has the new OBD2 test
Old Oct 31, 2003 | 11:47 PM
QCKZ28's Avatar
how many miles on your current cats?
Old Nov 1, 2003 | 12:06 AM
turbo_Z's Avatar
Oxygen sensor heater would mean one of your front O2 sensors is bad. replace EGR valve and the catalyst thing im not too sure about.. which one? if they were just reading PCM outputs then im guessing the bad front O2 sensor is causing the PCM to dump in tons of extra fuel which disrupts efficiency of the cat and triggers the rear O2 sensor code on that same side. but im only guessing about the cause.
Old Nov 1, 2003 | 12:14 AM
acid5868's Avatar
It currently has about 45k on the cats and O2 sensors. As far as the EGR valve anyone have a general idea how much that would run me?
Old Nov 1, 2003 | 12:34 AM
QCKZ28's Avatar
i have an EGR valve that worked fine when i took it off my car, didnt throw any codes, pm me and ill let you have it cheap.
Jesse
Old Nov 1, 2003 | 01:04 AM
MentalCaseOne's Avatar
is it the same type of EGR?? his is a 97 isnt it?
Jeff1904
Jun 5, 2016 05:00 PM
colts0455
Sep 11, 2015 06:16 PM
damnyankee36
Sep 9, 2015 07:06 PM
Jmj93z28
Jul 8, 2015 10:01 PM
colts0455
Jul 8, 2015 12:21 AM
