Failed Smog!
Old Nov 18, 2003 | 01:05 PM
jesterin's Avatar
Exclamation Failed Smog!
Hey guys i just had to smog my car at a test only facility and my car failed horribly. its a 94 z28, i got a moroso high flow intake, high flow cat and spintech muffler. my elbow(maf to throttle body thingymagig) is torn pretty bad, could that be a problem? any input will be great.. thx in advance.
Old Nov 18, 2003 | 01:16 PM
IXLR894Z28's Avatar
The tear in your elbow would definately be a starting point, then plugs, wires, etc...
Old Nov 18, 2003 | 01:46 PM
RedPhenx's Avatar
what did you fail exactly? and the elbow would def cause a problem
Old Nov 18, 2003 | 01:48 PM
aintno6's Avatar
Im gunna say the high flow cats are part of the problem.
Old Nov 18, 2003 | 05:30 PM
MattK's Avatar
Don't buy the high flow cats argument - I passed with a pair of Random Tech without any problem at all. They're kind of a non-issue from my experience.
But a torn intake elbow will be a significant problem as the vacuum leak will cause higher fuel pressure which causes you to run rich. Did you fail HC or something else?
Old Nov 18, 2003 | 06:08 PM
Fuels94TA's Avatar
To help pin point the problem what readings did you get from the test? Yes a torn elbow will do something to the test, and dont you fell like the car idle rough.
Vinny
Old Nov 18, 2003 | 06:22 PM
b-stevens's Avatar
I would hate to drive my car if the elbow was torn, in fact, i probably wouldnt until i fixed it. Who knows what kind of **** your sucking up from the engine compartment.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
